Steering column bearings? - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 02-15-2011, 04:09 PM
brad7.3 brad7.3 is offline
brad7.3 is starting off with a positive reputation.
Hey fellas, I'm pretty sure the bearings in my steering column are shot. How much of a hassle is to change the bearings? Or would it be easier just to replace the whole column?
Old 02-15-2011, 04:51 PM
J'S97F-350's Avatar
J'S97F-350 J'S97F-350 is offline
J'S97F-350 is starting off with a positive reputation.
not verry difficult of a job. I did it with the steering colomn out of the truck, so it might be some what harder in the truck...don't think there will be much diff. hardest part is getting the steering wheel off because ford did not give much room for a puller
part numbers
# F4DZ-3517-A, F3TZ-3517-A and a ring kit F0DZ-3L539-F
1st 2 numbers are the upper and lower bearings and the last is the snap ring and bushing that goes above the top bearing. around $20 fof all 3 from ford.
Old 02-15-2011, 05:41 PM
Ok, thanks. My ford dealer won't have the bearings till thursday, but I'll let you know how doing it with the column still in the truck works.
Old 02-15-2011, 05:56 PM
helifixer's Avatar
helifixer helifixer is offline
helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.
if your truck in an auto transmission replace the plastic bushings on the shift lever while it is apart. I will look for the part number.
Old 02-15-2011, 06:00 PM
helifixer's Avatar
remove wheel, remove canceling cam, if it is still installed remove snap ring, you will most likely find a broken tension spring. as you dig deeper you will find both bearings have lost all the *****. ford has a service kit for this. while in there if the truck is an auto i replace the bushings on the shift lever also.
F4DZ3517A bearing
F3TZ3517A bearing
F0DZ3L539F ring - tolerance (This should have the spring and snap ring)
F3TZ7L278A bushing (this should be the bushings for the shift lever)
my cost on all this was $44, list was around $60.
Bart
Old 02-15-2011, 06:06 PM
Excellent, I've been hearing a "springing" sound for a few weeks, it's been irritating me, but not as bad as the whole
steering wheel locking up when I'm driving thing it's been doing for a couple days!
Old 02-15-2011, 06:08 PM
helifixer's Avatar
if it has been bad very long it destroys the aluminum housing, than you get to go to a wrecking yard and get another one and re build it!
Old 02-15-2011, 06:24 PM
Like I said the springing for a few weeks, and the bearings a couple days. And I don't drive a bunch of miles, hopefully it will be ok!
Old 02-16-2011, 02:55 AM
Nsaan's Avatar
Nsaan Nsaan is offline
Nsaan has a great reputation on FTE.Nsaan has a great reputation on FTE.Nsaan has a great reputation on FTE.Nsaan has a great reputation on FTE.Nsaan has a great reputation on FTE.
The column is not that hard to pull out. I broke the end off the shift shaft a few months back. I got a junk yard column and pulled it and swapped the parts. It only took like 2 hours to do the whole thing.
Need source for steering column bearings oleglass 1973 - 1979 F-100 & Larger F-Series Trucks 6 05-31-2015 06:45 PM
Steering Column Bearing Replacement Mercmeister 1961 - 1966 F-100 & Larger F-Series Trucks 15 01-29-2015 02:35 PM
steering column R. Tovar 1967 - 1972 F-100 & Larger F-Series Trucks 18 11-19-2014 07:28 PM
Changing bearings in steering column idealtrucks 1967 - 1972 F-100 & Larger F-Series Trucks 5 11-29-2006 11:45 PM
Steering column bearing removal? 73FOMO 1973 - 1979 F-100 & Larger F-Series Trucks 13 04-11-2006 12:48 PM
Tags
1986, bearing, bearings, change, column, f0dz3l539f, f150, f250, f3tz3517a, find, ford, retaining, ring, steering, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
