New distributor install advice needed - Ford Truck Enthusiasts Forums
Old 02-15-2011, 03:32 PM
Lakerat's Avatar
Lakerat Lakerat is offline
Lakerat is starting off with a positive reputation.
I am installing a new Mallory distributor in my rebuilt 300. I have seen 2 methods for this procedure, which is best?
1- Set #1 piston to 0 degrees top dead center on the compression stroke, and install the distributor so that the rotor points directly too the #1 spark plug terminal. Then time the engine with a timing light during cam break in.
or
2- Set the #1 piston to between 10 & 14 degrees before top dead centre on the compression stroke (using the timing marks on the harmonic balancer), and install distributor so that the rotor points directly at #1 spark plug terminal. Then check & fine tune the timing during or after cam break in.
Mallory told me to use method #1, as method #2 will not work, but I have seen meathod #2 used on other engines.
Old 02-15-2011, 05:05 PM
dustybumpers's Avatar
dustybumpers dustybumpers is offline
Posting Legend
dustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputation
method 1. method 2 won't work.
Old 02-15-2011, 05:19 PM
AbandonedBronco's Avatar
AbandonedBronco AbandonedBronco is offline
AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.
Do you also need to line up the stator inside the distributor? I'm not familiar with the Mallory unit, so I don't know if it has one.
On the stock unit, you have to be absolutely certain that an arm on the stator is lined up perfectly between two alignment marks on the magnetic pickup. Each 1/4" off is like 7 - 10 degrees off timing or something.
I've used Method #2 before and it worked flawlessly. Again, on a stock Duraspark II unit.
Old 02-15-2011, 08:45 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc BaronVonAutomatc is offline
BaronVonAutomatc is gaining momentum as a positive member of FTE.
Mallory's are usually optical triggers, fwiw.
Old 02-15-2011, 08:51 PM
Harte3 Harte3 is offline
Harte3 is gaining momentum as a positive member of FTE.Harte3 is gaining momentum as a positive member of FTE.
Question: "... which is best?"
Answer: "Mallory told me to use method #1"
Old 02-16-2011, 11:42 AM
Quote:
Ahhh... Makes sense.
?DB2 Automatic Advance ADJUSTMENT? and I/P Timing HELP Needed in Germany Fixnstuff Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 51 06-17-2016 10:26 PM
DSII timing help needed surf-SIX 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 01-02-2016 08:46 PM
1968 F100 timing issue johnie ryall 1967 - 1972 F-100 & Larger F-Series Trucks 20 09-12-2014 04:49 PM
new distributor help jshad101 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 06-27-2014 04:45 PM
Timing issue1995 - 1995 F150 5.0L rlh68050 1987 - 1996 F150 & Larger F-Series Trucks 4 09-13-2009 01:23 PM
Tags
300, 302, 352, 49, beswt, distrebuter, distributor, ford, instal, install, installation, installing, rebuilt, truck, video
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
