Bak Flip or Retractable Cover with Bed Insert?
Hi Guys,
I recently bought an 07 F-150 SCrew and would like to install either a Bak Flip or Pace Edwards retractable bed cover. I know the advantages and disadvantages of both and had the PE retracractable on my previous F-150 for years without any issues. I'm thinking of the Bak flip for the 07 to save a few bucks over the PE.
While my previous truck had a spray on bed liner, the 07 has the factory plastic insert, so now I'm not sure about fitment. Has anyone had any experience fitting either of these two covers into a bed with the factory insert.
Thanks,
Fred
Thanks,
Fred
IIRC they should both fit with the drop in liner. Reason being is that the bed rail caps are a factory item, same on any F150 from the 04-08 run, aside from the Mark LT which had those chrome nerf bars on the rails.
I have a soft cover that was not troubled by my liner, just had to push the liner aside to secure the clamps.
I just checked out Pace's site, and the clamps shouldn't be a problem there either.
Thanks for the reply. I just seems like the bed liner is curved on the front endges which might interfere with the retractable box dropping down into it if I go that route. I believe you are right on as far as the claimps fitting up under the top mldg since the bed liner slips under it as well.
Fred
Fred
my996duc1
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
15
12-23-2012 11:33 PM
scottland7
07-18-2006 05:14 PM
