5th wheel lube- grease or lube plate?
I'm not sure how you can get grease all over the place when just lubing the pin or jaws, after changing to a lube plate in the late 80s I have never had that problem. My guess is your using to much grease. I just use a small amount of white grease and cover the pin with a piece of 2.5" pvc pipe when not in use.
Denny
Denny
There are usually 2 different sized plates for sale. I found that the larger one didn't tear as much (for ME). But even if I had to replace it annually, it wound be better than messing with the grease. So I use the teflon plate and use the Fluid Film on the jaws and other moving parts of the hitch.
I'm still using the same teflon plate that was on the trailer 8 years ago when it was new, maybe it's the way you are hitching up that causes the problem. I always raise the trailer high enough so that it's just about the same height as the hitch before I back under it.
Denny
Denny
Denny
The guy I bought the trailer and hitch from I think was a little crazy with the grease LOL. When I hitch up, I always wind up picking the trailer up with the hitch. Just like I do when I hook up a tractor trailer, but maybe that doesn't work as well for smaller trailers and / or teflon plates. I'm just tired of getting that one small spot of grease on my damn clothes when I pull the hitch out of the truck. I'll try a lube plate, worse cae scenario is I go back to grease. Thanks!
I use the teflon plate, works well, never binds. Also when I take the hitch out, I use suran wrap and cover the top part of the hitch as I do have grease in the jaws. That keeps critters, (wife, daughters, snoopy people) from getting grease on them while stored in the garage. Also my hitch is a 2 piece so I have 1 gigantic pin for the head of the hitch that is greasey.
I don't use grease or the teflon plate. Just hitch up dry and go. Of course I use a pullrite superglide. That makes a bit of a difference. I do use slip plate on my way tubes. Sure is a lot less of a mess than white lithium.
Is a graphite lube an acceptable solution for a standard 5th wheel hitch instead of grease? It may not be...
