1979 F250 WITH INLINE 6 CYLINDER
My guess would be 14-15.I am hoping mine improves with a tune, but we'll see. The way I look at my old trucks is that they are fun to drive. When I worry about economy, I drive the economy car
I have a 79 F350 dually with a 12' Dump on it and a 300 I6 motor. The engine is real wore out but still has the power to get a load moving and bring it up to highway speed. It gets about 14mpg loaded or not. My nicer 78 with the exact same setup but a 400 V8 gets 9MPG. Guess what one gets drove more!
-Jim
-Jim
I have a 79 f250 2door longbed 4x4 bought her in july 2010 and it also has a inlinet with a 4spd granny.mine gets around 6-8 miles to a gallon.these ole trucks dont do great on fuel but hey they look great and are eye catchers. you cant go wrong with the inline.so in if your lookin for a solid motor you should go with a inline 6.
You need to get your answers over at the I6 forum. I have an F350 that I swapped from a 390 to a 300. My goal was to retain the hp, but yet achieve 50% better mpg.
I now get 17 mpg on the freeway with 3.31 gears and a C6. Before I got 10, rain, shine, empty, loaded. I am now packing the nuts away so I can swap it over to a ZF five speed manual. Not only will you get better mileage with a manual, but you'll regain about 30 hp.
Changing over to the 300 worked out great for me.
Good luck.
There is loads of info available at the Inline section of this site. Also try fordsix performance.com. The first thing to do is to decide what you want your engine to do. I mean do you want it to turn 7k rpm, or just make a good daily driver with a pair. Once you know what you want, then you start buying the parts to get there.
Good luck.
Well to begin I di enjooy your choice of words, "or just make a good daily driver with a pair"....... I have to stop laughing. But in fact that is what I plan to build, good daily driver with a pair. Any suggestions??
Thanks.
Good luck.
Thanks.
The nice thing about the 300 is that you can about double the hp and retain nearly the same mpg. If you want to see some nice gains, you have to start with the head. It is the bottle neck of the engine. It needs to breathe easier, to flow more. That is done with a simple $350 porting job, cleaning up the bowls and runners, polishing the c.chambers. With that add a 30* back cut on the intake valves to a 3 angle v.job, and you are taking a major step to waking up your engine.
Add to that a nice Offenhauser intake, and a good 4v carb, and the efi exhaust with dual 2" or 2.25" pipe, or single with 2.5" pipe, and you will have quite an engine.
I have a series of articles about how to wake up the 300 in true blue trucks magazine, and write a column for them called backyard mechanic.
Good luck.
#29
Have a 300, 79 F150 4X4 short bed in about 1000 pcs at the moment, I have had it since 1980. I am on my second engine with a total of 250,000 plus miles on the truck, Would have rebuilt the first on but scored almost new one for very cheap. 15-17 MPG all the time, hwy or town. I do not think much will out pull it locked in and 4lo. Current work is getting my 79 F250 4X4 in for paint, its a long bed two holer and needed a new bed real bad. Super nice forum.
Boots on ground
15
01-18-2017 02:42 PM
BTKopf
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
23
07-06-2016 06:20 AM
jprice62
08-02-2012 11:00 AM
jcheinen
02-13-2012 10:57 PM
