Ok, it finally got done. I replaced the plugs over the weekend, it took me two days at about 2 hours each day. The process went pretty much as it's been described here so there were no surprises. I bought the Motorcraft Platinum plugs and the boots from NAPA. There was only small amounts of debris and dust in each of the holes so they were easy to blow out. When I pulled that first coil off I was frankly shocked at the condition of the boots. My previous Ford was an '83 GT and the rubber parts in that car were absolutely crap. Ford has really stepped up in quality, these boots were still clean and plyable, with very few cracks:
Only one looked like it had been arcing at some point:
Then the plugs came out, again I was shocked. For 112K miles they really weren't bad:
I have to say the driver's side was considerably easier in spite of having to remove more stuff to access the plugs; probably because, unlike the passenger side, the plugs "tilt" towards the front of the truck.
Here's the NAPA boots and springs:
I didn't use the springs because of the "contact pin" in the original spring wouldn't come out easily. DON'T TWIST IT, IT WILL BREAK. Trust me.
Since the second bank went so smoothly I looked for other things to do while I had things apart. This is a good time to clean the Throttle Body, so I did. I also replaced the only rubber vacuum hoses that didn't seem to be of the same quality as the rest of the engine; maybe the were just exposed to a lot more heat. When I touched them they crumbled in my fingers:
Here's the replacement:
My only "issues" were self-inflicted. When I finished the first bank, I started the truck and had a terrible miss. I started pulling the coil wires one by one, when I got the third one .... it was already unplugged.
The other problem I had was on the drivers' side. I dropped the fuel rail screw onto the manifold, then I forgot about it. When I pulled the coil .... plop! Down it went, I got it out with a magnet.
Here's the tools I ended up using, I taped all the sockets, u-joints, and extensions together ... just in case.
Anyway, my thanks to everyone here who posted one tip or another, and an especially big thanks to Racerguy. Wouldn't have attempted this job without all the info you folks provided ......... and you saved me about $200.
