1974 330 industrial engine - Ford Truck Enthusiasts Forums
Old 02-14-2011, 05:38 PM
TreeMan2010 TreeMan2010 is offline
TreeMan2010 is starting off with a positive reputation.
Hello,I have a hole in the intake manifold of this engine.Don't know how to find new one or JB weld this one.HELP!Anyone!thanks Shawn
Old 02-14-2011, 06:32 PM
raytasch's Avatar
raytasch raytasch is offline
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
A picture would be helpful in making a suggestion. JB weld may work. Drill, tap and plug may work. Drill tap and install a small plate to cover the hole may work. Depends on the size, location and proximity to any moving parts may determine the repair. I would think this is a cast iron manifold. If, by slight chance it is the FE series engine it should not be that much problem finding a replacement but my guess is it is the big truck engine you are speaking of.
I would suggest you post over on the engine forums. Good luck.
Old 02-15-2011, 07:31 AM
maverickman514's Avatar
maverickman514 maverickman514 is offline
maverickman514 is gaining momentum as a positive member of FTE.
I just looked at a 74-5 F600 with a 330 in it..... looked like a FE MOTOR to me...
Going with 2 different 351 engines. pweng1 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 04-29-2016 08:26 AM
Engine Lift OTC#303-D043 Toyman 6.0L Power Stroke Diesel 36 01-25-2016 04:44 PM
302 Engine dsmit412 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 06-01-2015 11:03 AM
engines that dont live up to there name robertdale Ford vs The Competition 328 10-27-2004 06:03 PM
1949 Engine Paint FORD PARTS GUY 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 03-15-2004 06:09 PM
Tags
1974, 330, engine, fe, ford, ig, industrial, intake, manifold, motor, specs, timing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
