1993 F-150 Leveling kit
My had 2 inch coil spacers on it with 33x12.5x15 BFG all terrains on 15x8 rims with I think 4 inch backspace. It only rub the radius arms, but just do not turn the wheels all the way. I have a 6 inch lift now with 35x12.5x15 and have the dual Rough Country stabalizers and it helped with the steering. I did not have or needed any stabalizers with the 2 inch coil spacer lift with the 33 inch tires.
Here a picture with the 2 inch coil spacers and 33 inch tires.
There are spacers. I went through all of this too. I finally went with the moog 844 springs. They are only like $68 I think. Some have said the 824 lifts it a little more (like an extra half inch or maybe a little more). Just FYI. I wanted the more heavy duty spring so I went w the 844 which is rated as the f250 springs and my truck is not quite level by like half inch however I do have a tow package which adds an extra rear leaf from the factory I believe.
Is that the picture of the 2" kit?
Im just confused. Id pull the trigger tonight if someone could tell me which spring lifted how much over stock, but there are diff answers everywhere, which is what is pointing me towards a spacer, cause that's a straight 2-2.5"
