Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 02-14-2011, 02:08 PM
fusionsp fusionsp is offline
Garage is empty, add now
fusionsp is starting off with a positive reputation.
Spark Plugs
Been reading a lot about the plug issues and was thinking of replacing mine @36k before I get too much mileage and hoping they will be easy to remove now. If not, my local part's store has the removal tools.
Will I have the same problem if I use new Motorcraft plugs or did they redesign because of this issue ? I've read that Champion has a 1 piece plug but not sure how well they perform. I never thought Champion made a good plug (in the past) compared to Bosch, etc.
Thanks
  #2 (permalink)
Old 02-14-2011, 08:15 PM
The Best Spark Plugs for a Ford 5.4 Engine | eHow.com
Just found this article. Looks like Motocraft did beef-up the 5.4 plug.
  #3 (permalink)
Old 02-14-2011, 08:49 PM
MCDavis's Avatar
MCDavis MCDavis is offline
MmmmmmKayyyyy
2006 Ford F-150
MCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputation
Regardless of the plug design, you'll find that your 5.4L will perform the best with the Motorcraft plugs in it.
The F150 guys that have put in Champion and other brands have found that after a few thousand miles they are having sputtering and hesitation issues, amongst other things.
I, and a lot of the truck guys, will recommend you stick with the Motorcraft plugs. You shouldn't have too much of a problem with an 07+ Expy as Ford had pretty much caught on by then and made a fix. You're not likely to break of 6-8 of them like the 04-06 F150 guys.
__________________
Chandler
Official Slackmaster #24
  #4 (permalink)
Old 02-14-2011, 09:36 PM
TheThickster's Avatar
TheThickster TheThickster is offline
TheThickster is starting off with a positive reputation.
As far as I know the main problem was carbon build up, to much carbon seizing the spark plugs.You could seafoam every oil change to help knock off some of the carbon, or IIRC you could get a can of carbon buildup remover from the dealer.
  #5 (permalink)
Old 02-25-2011, 05:47 PM
Just got done removing all 8 and didn't break any. Took my time and soaked each one with carb cleaner after loosening. All I need to do now is figure out which Motorcraft plugs to use. My dealer quoted me $26 each!! Not sure if I need to go with the SP507 or the SP509 plug from Motorcraft. Anybody know the new part#?
Thanks
Shawn
Tags
42, aviator, black, carbon, ford, lincoln, plug, sp509, spark
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
