Need help, Steering Box
Hey guys, i could use your help, please check out this thread:
https://www.ford-trucks.com/forums/1...ml#post9966388
You almost need some special tools to get the box off the truck. A pickle fork to seperate the pitman arm from the drag link. Flare nut wrenches to remove the pressure lines from the top of the box, you may get them loose with an open end wrench but you don't want to round them off. Other than that just basic hand tools to get the box off the vehicle. After the box is removed from the vehicle you should have a pitman arm puller to remove the pitman arm from the box, a regular puller may work but some of them are really tough.
The seals come in kits. A bottom kit(which you would need) and a top kit where the steering wheel shaft goes in. It would be your call as to whether to use a top kit. Don't try to use up all the parts in the kits.
I clicked on the link you posted and skimmed through it. There was mention of removing those steel *****, I personally don't go that far, I just install the outside seals and associated parts. Good luck.
