Won't Shift Into Park - Ford Truck Enthusiasts Forums
Old 02-14-2011, 09:17 AM
dave47111's Avatar
dave47111 dave47111 is offline
dave47111 is starting off with a positive reputation.
Got to work this morning and went to put the truck into park and Felt the suttle bump of going into Reverse Fooled around with it and it seems that now Park is reverse and drive is Neutral. Thank goodness the parking break works.. I have heard of issue like this, What to I need to do to fix it?
Old 02-14-2011, 09:29 AM
Slip ford man's Avatar
Slip ford man Slip ford man is offline
Slip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud of
Don't know what truck you got, but its either a rod or a cable that needs a look at. In the past I had a 3/8 piece of rope tied to the trans shifter ear, running up through the 4x4 shifter boot, that I would pull to get her into park...necessity being the mother of invention.
Old 02-14-2011, 09:45 AM
dave47111's Avatar
Sorry, The truck is a 95 f150 4x4 flareside. I believe it has a cable shift.
Old 02-14-2011, 11:12 AM
77h0t_r0d_wrecker 77h0t_r0d_wrecker is offline
77h0t_r0d_wrecker is starting off with a positive reputation.
Sounds like the cable stretched out enough that it won't allow the vehicle in park even when the dash reads it's in park.
Take a roll in the dirt underneath and locate the shifter on the trans. There should be a bolt and nut that hold the cable in place, and you should have about a 1/2 inch of play on either side. What you want to do is loosen that cable, make sure the truck is in park at the trans, then put the shift lever ALL THE WAY to park. The bolt should have moved a bit, and if you tighten it in it's new place, that should solve your problem.
Let me know how it works out
Last edited by 77h0t_r0d_wrecker; 02-14-2011 at 11:17 AM. Reason: added a bit of info for clarity
Old 02-14-2011, 11:44 AM
dave47111's Avatar
Thanks for the Info, I will check it out as soon as I get home.
Old 02-14-2011, 11:55 AM
rikard rikard is offline
rikard is gaining momentum as a positive member of FTE.
Before rolling in the dirt look at the bottom of your steering column under the dash and see if the bolt has come loose from the column shifter rod like it did on my 92.
regards
rikard
Old 02-14-2011, 01:10 PM
dave47111's Avatar
Quote:
regards
rikard
I will do that as well. Hoever, as my luck usually goes I will end up rolling around in the dirt.
Old 02-15-2011, 07:48 AM
dave47111's Avatar
Got it fixed. It turned out that one of the bolts had worked its way out from the shifter on the column! EZ fix and is actually better than before,becuase I dont have any play
95 f250 reverse gear problems Sam's The Man 1987 - 1996 F150 & Larger F-Series Trucks 5 03-06-2016 07:28 AM
Park assist problem 50man 1997-2006 Expedition & Navigator 5 07-03-2012 12:42 AM
How to adjust parking brake? rolloman 1997 - 2003 F150 2 03-20-2012 08:08 PM
Truck won't go into park HELP!!!! cclc1021 1994.5 - 1997 7.3L Power Stroke Diesel 10 06-27-2011 08:33 PM
Trailer Parking Light Relay Location teg2_nv 1999 to 2016 Super Duty 8 03-16-2006 10:20 AM
Tags
1994, 1995, 93, aod, f150, f250, f350, ford, grears, park, reverse, shift, truck, wong, wont, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
