3v heads on 99 shortblock
As for bolting on and functioning, the shortblocks are the same-it's all of the top end that's different.
JL
Owning both verisons of the 6.8L, I can tell you for certain that the 3V is a night and day difference in power over the 2V. You're just gonna need the 3V PCM to properly control it, which also means that if you're older truck has a 4R100-you're gonna have to swap transmissions too-the 3V PCM's will not control a 4R100.
JL
JL.
Anything is possible with enough motivation ($'s)
If you go ahead with this, PLEASE take pictures, especially when you get to the cam gear.
Someone here once did this, and the problem he eventually had was the check-engine light on for the cam position sensor (CPS). It ran, and apparently had more power than the 2-valve, using the 2-valve PCM, but he had that check engine light on.
He had to fabricate an adapter to get the 2-valve throttle body to match the 3-valve intake, and he fabbed up some type of vacuum-operated setup for the variable plenum which (to me) was not optimal.
But the real bug was the CPS. I suspect it is somehow electrically different, not so much position, but signaling.
Well there has been a couple of guys doing this conversion on 4.6 engines. Logan motorsports sells a kit for this conversion aswell as mmr. I dont want to install the variable plenum. But what I realky want to know is if the 3v heads are gonna have much more hp than doing a pi head conversion on a 99npi block? I know if I put some pi heads with the raised cr it would give me maybe 40 more hp. Anyone know what cc is the cumbustion chamber of the 3v head?
You don't get a choice on the variable plenum-it's an integral part of the 3V 6.8L intake manifold.
NPI heads=52cc
PI heads=44cc
3V heads=50cc
JL
