Cab tag Decode please - Ford Truck Enthusiasts Forums
Old 02-13-2011, 09:52 PM
Sleepy445FE's Avatar
Sleepy445FE Sleepy445FE is offline
Sleepy445FE is gaining momentum as a positive member of FTE.Sleepy445FE is gaining momentum as a positive member of FTE.
Some of this is obvious, but the rest I don't know.
The tag on the firewall reads:
F26YRC31472.....................................18-152
YA 133 ....BDY.....4N(W maybe?)AR
JA COMB.....MLD....XLT.....RKR
......Y..............................CAB
Thanks fellas!
Old 02-14-2011, 07:10 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Is this the tag on the firewall? If it is, it's a "buck" tag. These were used by the assembly line workers durring the building of the truck.
Not all trucks had buck tags.
As far as I know there is no "decoding" these tags.
Old 02-14-2011, 09:43 PM
ah I see. Dang that sucks. Someone swapped a 76 150 driver door in at some point so I don't have the tag there. I guess I'll never know what this truck came with. Thanks for the reply, I learned a new term anyways.
Entering buck tag into the brain database.lol
Old 02-14-2011, 10:02 PM
kev78 kev78 is offline
kev78 is starting off with a positive reputation.
from what i come up with f26 73 up f 250 4x4 pickup, y is 360 2bbl, r is san jose assembly plant. hope it helps
Old 02-14-2011, 10:40 PM
Thanks for the reply. I've had the actual vin decoded, of which you are correct, it's some of the rest that I dunno about. I mean obviously 133 is the wheelbase, XLT is just as it says. 4NAR is some type of 4x4 designation I'm guessing. But like what is COMB, or YA, or JA, or MLD, or RKR!??! lol If mike says there's no way to decode it, I'm not gonna keep up any hopes.
Old 02-14-2011, 10:59 PM
bucks77ford's Avatar
bucks77ford bucks77ford is offline
bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.
If you have the VIN you can get an original build sheet from Ford for free. It just takes a few weeks. Mari Auto Works can do better, but you have to pay for the info.
Old 02-14-2011, 11:08 PM
Niiice! how do I go about doing that? When you say they can do better, do you mean time frame wise?
Old 02-14-2011, 11:15 PM
Quote:
They offer more detail for more money. Check out their website. I should say for the more expensive reports. Their basic one I think is what Ford will send.
Marti Auto Works - Concourse Quality, Hobbyist Price
I believe this is where I asked Ford about the original build sheet than I received an email that stated the question was being forwarded to the history department and then a few weeks later I received it in the mail.
Owner Support - Ford
Old 02-14-2011, 11:33 PM
Thanks a ton! reps given!
Old 02-14-2011, 11:38 PM
Glad I can help. Through Marti, you can also order new door jamb sticker and VIN plate if needed.
Old 02-14-2011, 11:45 PM
I'll probly get that door jamb sticker and vin plate. Then no one will know it has a different door. haha Thanks again.
Old 02-17-2011, 07:58 PM
So I was going to get the one from ford first. Is it just impossible to contact them online? In the link to them that faq search doesn't work no matter what I type in. And when I try to contact them by email they require the vin number, which they of course say that our 11digit vin is not complete. Do you just have to call them?
Old 02-17-2011, 08:31 PM
You might have to now since the idiots probably are just taking the word of a computer and have no insight to old trucks. If you call, they should be able to direct your call. Just can't find good help these days. I got mine 4 years ago, so things may have changed a little or just depends on who took the email from you.
If you do plan on getting a tag and sticker, than I'd just go with the Marti Report.
Old 02-17-2011, 08:45 PM
Well you can't even email them without the vin#. And an 11digit vin apparently doesnt exist in their computer. I guess I'll just call them then. I do want to get the Marti report, but I'd probly get the $15 one and then the $60 report on how many were like it and such. Just out of curiosity.
For now I dont have 85 bucks for it. So I was gonna just get the free Ford sheet. Thats before I new their site was also Sheet. lol
Old 02-17-2011, 09:49 PM
I was browsing around with Ford's Websites and I think I found the one that I used. When I posted the previous link for you, that came directly from the Tips/Tricks sticky, but I didn't remember going through that link. But, it's been awhile and websites change. However, I think when I inquired about a build sheet, I actually emailed Corporate using this web page. I emailed the information/VIN of my truck and someone from Ford had forwarded it. I couldn't find my email, I must have deleted it. Might be a try if you prefer email.
https://secure.corporate.ford.com/fo...neralCorporate
Front axle identification no tag? kyle j 1994.5 - 1997 7.3L Power Stroke Diesel 4 12-05-2016 10:01 AM
New Vin plate from Marti Auto Works Oz Econoline 1973 - 1979 F-100 & Larger F-Series Trucks 33 06-25-2016 12:36 PM
Cab swap, what to do about VIN tag? bulletsneverlie 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 21 07-01-2015 09:34 AM
Need to know where VINs are located scld1354 1999 to 2016 Super Duty 12 05-27-2015 06:29 PM
rear axle tag numbers i1dery Clutch, Transmission, Differential, Axle & Transfer Case 25 03-04-2006 03:38 AM
Tags
1976, 85, buck, cab, decoder, decoding, f250, firewall, ford, id, ja, np435, plate, tag, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
