PMT arms were installed by a professional mechanic. It took 2 hours total. The arms had to be installed at the same time (PMT stated they can be installed one at a time) which caused the well-known axle twist. Everything fit OK. Interestingly, the front driver side bolt DID NOT have to be cut as stated elsewhere on this site. Thanks for all your help and advice.
