Ground wire on hood bracket????
Old 02-17-2011, 12:12 PM
okmd58's Avatar
okmd58
okmd58 is offline
Help! 1999 Mountaineer, V6 engine. I found a broken black wire approximately 6 inches long hanging on the bottom of the passeger side hood bracket with a terminal connection. I cannot find the other end to determine what it goes to. Can anyone help with this? Thanks
Old 02-17-2011, 08:57 PM
shorod's Avatar
shorod
shorod is offline
Gonna need a few more details. What year is your Explorer? What color is the wire? Where precisely is the one end connected?
-Rod
Old 02-17-2011, 08:59 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
should be a terminal end under one of the hinge screws or close to it... There are several bare ground type wires from the hood to the body, motor to the frame, body to the frame, etc... this makes sure everything has a ground back to the battery, thru painted or rubber mounts.
Old 02-18-2011, 01:05 PM
okmd58's Avatar
okmd58
okmd58 is offline
Thanks Steve for the reply. Let me try again with more information. 1999 Mountaineer, V6 engine. I found a broken black wire approximately 6 inches long hanging on the bottom of the passeger side hood bracket with a terminal connection. I cannot find the other end to determine what it goes to. Can anyone help with this? Thanks
Old 02-18-2011, 02:46 PM
gasman6674's Avatar
gasman6674
gasman6674 is offline
Could it be a hood light?
