Banks Big Head Wastegate Actuator installation, I NEED HELP ASAP!!!!!!!!!!!!!!!!!!
This is turning out to be the worst BDAY ever. I am never going to do anything else to this truck again. The damn butterfly valve or whatever the damn rod slides down is jammed backwards and i can't get it to move back into position so i can put the rod on it. DOES ANYONE HAVE ANY SUGGESTIONS? Do i have to pull the turbo out now and fix the ****ing valve?!
Maybe this pic will help. Wastegate fully open.
You can apply regulated air pressure to the actuator no more than 10-15 psi. That will extend the arm out and allow you to hook it up. IIRC the instructions tell you to adjust the rod end to just go over the pin for the wastgate lever. Then thread it in a few turns, and you should be good.
It is nothing hard, just not in the best location. As mentioned tie floss onto the clip to retreive it when dropped.
I am still in shock. I made this post after trying to get that damn valve to move for 20-30 minutes. I had tapped it with a screw driver, tried pushing it back with all my might and nothing would move that damn valve. I made this post went back out there touched it and it moved so easily the only explanation i have is something else helped me move it. My dad was just talking about pulling the entire thing apart to unjam it (which i imagine is taking the turbo off) Then everything went together so easily, the C-Clip got it on first try, the nuts all went on first try and were so easy to tighten up unlike taking them off. I can't believe it still.
