Highboy steering conversion, do i have the right box?
Im going to be doing the highboy steering conversionon my 76 before to long but i need to know if i have the right box. This box came with some other parts when i got the truck, it looks right but im not sure. Second question is what else do i need? Just a drag link from a 78/79? What about the steering lines, are they a direct swap for the new box? Thanks for your help.
That is the box I used to convert mine, boxed in the frame inside, drilled the boxing then put sleeves inside the boxing to keep from crushing the frame.
Again yes that is also the box I used as well so it can work with mods done.
I had new lines made for mine so I do not know if your lines will work.
The drag link would be the one for the 78/79 F250 4x4 or 79 F350 4x4.
http://broncograveyard.com/bronco/i-...drag-link.html
I have done a few of them with the 77.5-79 box like you have. After getting the frame cut out so the box fits up in there I hook the steering shaft and the drag link up to the box & steering arm so it's all in there, hooked up. Then position the box for the best fit. Then take it all back out and finish up the frame. That way no problems will creep up on you as you are hooking up the shaft and drag link.
i got the PS box off a 79 f250 4x4 i will be putting in my 71 crew cab i drove my crew before i parked it and started on the floor replacement and cab mounts this spring i will be doing the steering swap ive checked different articles on it does anyone have some pics of there process of the swap you could post for further references i can't wait until it's done and feel the difference
1972fordhighboy2
03-24-2016 07:54 AM
lpdcjr
02-08-2016 05:55 AM
Xauterus
15
01-23-2012 10:38 PM
blackkawi400
38
08-01-2010 01:58 PM
1977 HIGHBOY
11-20-2009 12:54 AM
1977, 76, 7879, box, boy, bronco, changing, conversion, conversions, ford, high, highboy, modification, steering, update
