F350 tire size - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
F350 tire size
Old 02-13-2011, 01:12 PM
tinman565 tinman565 is offline
tinman565 is starting off with a positive reputation.
F350 tire size
Ok...I hope this is my last question for awhile. Whats the largest tire I can fit on my '05 F350 SD DRW 4x4 CC ? Tallest, widest...etc ? I heard something about making sure they dont rub together on the backs ? The truck now has LT 245/75 R 17 121/118 R Load range E. Thanks again for all your help.
Old 02-13-2011, 04:05 PM
Anybody ?
Old 02-13-2011, 11:11 PM
Sigh
Old 02-14-2011, 05:50 AM
BigPigDaddy's Avatar
BigPigDaddy BigPigDaddy is offline
BigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to behold
I have no idea, but I didn't want you to feel ignored.
Can you check with a local tire dealer?
Old 02-14-2011, 08:07 AM
Thanks BPD...lol.
Somebody must know.
Old 02-14-2011, 08:41 AM
thedaddycat thedaddycat is offline
thedaddycat is gaining momentum as a positive member of FTE.
I have 33" (285/75R16E) tires on my '03, but it has leaf springs with a helper leaf to bring the spring rating up to 6000# for the snow plow. I think you can go up to about 35" but may have some rubbing issues at full lock when turning, and may need a leveling kit. I prefer taller tires but not wider ones, but the width will matter as far as rubbing. Also, if you are getting new wheels you need to check the offset and backspacing. I believe more negative offset moves the wheel outboard and will allow wider tires. Sites like Tire Rack have articles on all the technical issues.
Old 02-14-2011, 08:53 AM
Thanks for the response sir. I'm looking more for tire height than width. I'd like to get the tallest I can without getting into spacers (but I'll use them if I have to). I'm keeping the stock wheels cause they are nice. Was just hoping to get a little more height when I buy new tires.
Old 02-14-2011, 11:00 AM
Fredvon4's Avatar
Fredvon4 Fredvon4 is offline
Fredvon4 has a good reputation on FTE.Fredvon4 has a good reputation on FTE.
I use Tire Size Calculator - tire & wheel plus sizing
to play with different sizes and see the availability of different sizes
Some folks claim up to a 315mm will fit the F350 with no need to lift or add spacers
Some words of caution:
Ford uses :Hub centric" mounting most cheaper aftermarket rims are "bolt centric".... the later will work but are not safe in my opinion if the truck is worked hard with heavy loads on twisting roads
In my sample below note the required rim width for the larger tire
The rear duallies require specific clearence BETWEEN each tire...Tire rack and other such sites will let you know if they will work on a duall rear wheel fittment
Be sure you look beliow at the revs per mile and understand that the Ford Tech can only adjust the speedo so far (I forget the upper and lower limits) however if you want to fool the computer there isa device called a TrueSpeed modul that you can insert between the VSS in the diff and the PCM to correct for the error
here is an example of the search at 1010.c om
Stock Tire - 245/75R17 new> 315/70R17
Section Width: 9.64 in 245 mm
Section Width: 12.40 in 315 mm
Rim Diameter: 17 in 431.8 mm
Rim Width Range: 6.5 - 8 in
Rim Width Range: 8.5 - 10 in
Overall Diameter: 31.46 in 799.08 mm
Overall Diameter: 34.36 in 872.74 mm
Sidewall Height: 7.23 in 183.64 mm
Sidewall Height: 8.68 in 220.47 mm
Radius: 15.73 in 399.54 mm
Radius: 17.18 in 436.37 mm
Circumference: 98.83 in 2510.2 mm
Circumference: 107.9 in 2740.6 mm
Revs per Mile: 661.1
Revs per Mile: 605.3
Actual Speed: 60 mph 100 km/h
Speedometer1: 54.9 mph 91.5 km/h
Speedometer Difference: - Speedometer Difference: 9.218% too slow
Diameter Difference: - Diameter Difference: 8.45%
1992 F350 4WD Rim Size regidog Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 21 12-14-2016 04:10 PM
Questions about tires ..... TruckingBill 6.0L Power Stroke Diesel 7 01-04-2015 04:05 PM
Tire Swap! Tugnut 1997 - 2003 F150 2 11-22-2014 06:34 PM
HELP! E350 Superwagon buckpago 1968-2013 Full Size Vans 5 07-05-2014 07:54 AM
Long Haul with a Ranger? SSBB 1987 - 1996 F150 & Larger F-Series Trucks 9 06-26-2014 06:49 PM
Tags
2000, 350, duty, f250, f350, ford, heavy, ks, size, specs, super, tire, tires, truck, wichita
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
