Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 02-12-2011, 11:09 PM
cato47 cato47 is offline
Garage is empty, add now
cato47 is starting off with a positive reputation.
92 F150 POWER WINDOW MOTOR REPLACEMENT
Gentlemen:
I just bought a 92 F150 Ext Cab 4X4 and the drivers side power window won't go up or down. The guy I bought the truck from gave me a new replacement motor but I don't have a clue on how to put it in or even get the door panel off without screwing something up. I'm very mechanically inclined but the truck is so nice I wish one of you out there could give me blow by blow instructions, start to finish, on performing this task. Window related repairs and door panel removal is something I've never had to mess with in my 64 years but it's time to learn now. Thanks in advance to all that give a helping hand.
Rick
  #2 (permalink)
Old 02-13-2011, 08:42 AM
subford's Avatar
subford subford is offline
subford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to behold
Power Window Motor, F-Series and Bronco
Removal
1. Disconnect the battery ground cable.
NOTE:
On vehicles equipped with EEC, when the battery has been disconnected and reconnected, some abnormal drive symptoms may occur while the EEC processor relearns its adaptive strategy. The vehicle may need to be driven 10 miles to relearn the strategy.
2. Remove the door trim panel and watershield. See PDF below.
3. Disconnect power window motor wire from wire harness connector.
4. Check inside the door to make sure electrical wires are not in line with holes to be drilled in the door inner panel. Using a 12.7mm (1/2-inch) diameter drill bit, drill two holes in the door inner panel at the drill dimples located opposite the two unexposed motor drive retainer screws.
5. Remove the three motor mount retainer screws using two drilled holes and existing larger hole access to screw heads.
6. Push the motor toward the outside sheet metal to disengage the motor and drive from the regulator gear. After the motor and drive are disengaged, prop the window in full UP position.
7. Remove the motor and drive from inside the door.
Power Window Installation, F-Series and Bronco
Click the image to open in full size.
Installation
1. Install a new motor and drive assembly and engage the motor to the regulator. Tighten motor retaining screws to 5.6-9.6 N-m (50-85 in-lb).
2. Install two pieces of Pressure-Sensitive Waterproof Tape D6AZ-19627-A or equivalent body tape (25.4mm [1 inch] square) over drilled holes.
3. Connect power window motor wiring. Connect battery ground cable.
4. Remove glass prop and check window operation.
5. Make sure door drain holes are open.
6. Install trim panel.
__________________
95 F150 302 4R70W EB EX-CAB
94 F53 460 E4OD COACHMEN SANTARA RV
83 F150 Flare Side 351W AOD
77 F250 351M-2V NP 435/4 Speed 4X4
subford@gmail.com
Bill K, Kansas Chapter
  #3 (permalink)
Old 02-13-2011, 09:22 AM
L. Ward's Avatar
L. Ward L. Ward is offline
1990 Ford F-250
L. Ward has a good reputation on FTE.L. Ward has a good reputation on FTE.
If you are not inclined to drill holes in the door panel as above, there is another way.
  1. Disconnect battery
  2. remove door panel, armrest support, and protective film
  3. take 2-3 strips of duct tape and loop over top of door and tape to both sides of window to hold it in the "up" position
  4. unplug motor
  5. using a small punch, knock the center out of the 4 rivets holding the regulator assembly in
  6. drill out rivets (1/4" bit)
You can now remove the whole regulator assembly to swap the motor. Also while you have it all apart, I would suggest cleaning the track on the bottom of the window and regreasing it. Also clean and regrease the regulator assembly.
To reinstall it, use SHORT 1/4 bolts. You will need to connect the battery and run the window down slightly to finish installing the last two bolts.
__________________
Speed costs money! How FAST do you want to go? '04 Excursion EB 4x4, 6.0 PSD, '94 F350 Crew Cab (Emergency Response Vehicle), 4x4, carbed 460 , E4OD, 4.10 Gears; '90 F250, carbed 460, E4OD RIP; '78 Bronco 460, C6 4" lift, 38" Swampers RIP
If I helped, please show some love above
http://www.ford-trucks.com/forums/10...2-11-10-a.html
  #4 (permalink)
Old 02-18-2011, 01:54 PM
MARC's Avatar
MARC MARC is offline
1959 Ford F-100
MARC is starting off with a positive reputation.
Do NOT throw out motor. take it apart from the back end where the two nuts are remove winding, shaft assembly. lightly sand copper surface of brush contact, flatten/file brushes flat for maximum contact, and reassemble. motor is much biger and stronger than replacement motor. I did this 3-4 years ago and had no further problems with motor. My problem now is when I roll window down fast it bumps the bottom and the window regulator pops off the motor gear. I remove motor and reinstall it it works until I forget and roll down the window too fast. Does anyone know which way to adjust the jam nut on the motor?
  #5 (permalink)
Old 02-18-2011, 02:44 PM
subford's Avatar
The ones I have seen are always too rusty to repair inside.
__________________
subford@gmail.com
  #6 (permalink)
Old 02-19-2011, 10:28 AM
MARC's Avatar
1959 Ford F-100
Wouldnt know about that, I live in Arizona.......tell me about this thing called rust...lol
  #7 (permalink)
Old 02-26-2011, 09:57 PM
bigtex94FE bigtex94FE is offline
bigtex94FE is starting off with a positive reputation.
Sorry new to the site gotta 94 f150. power window motors sound *** if working but do not move windows in the slightest , lol of course I can do it manually...throwing the window up and down, but the motors sound strong and want to with is there a simple fix I'm not seeing ? before I go expensive route and actually break down and buy some replacement parts I'm fairly smart just new to the truck and doesn't add up are there resistors in the switch or am Ion wrong path...desperately seeking your help thanks... drew
  #8 (permalink)
Old 02-26-2011, 10:10 PM
Encho's Avatar
Encho Encho is online now
Encho is a splendid one to beholdEncho is a splendid one to beholdEncho is a splendid one to beholdEncho is a splendid one to beholdEncho is a splendid one to beholdEncho is a splendid one to beholdEncho is a splendid one to beholdEncho is a splendid one to behold
Hi bigtex, welcome to the site, what you're describing sounds like the link between the window and the motor isn't there, take down the door trim and have a look inside.
__________________
1993 Special Edition Bronco: 5.0lt V8, E4OD Auto, MM Supreme manual hub lockers and a sweet roof tent, ROTW in 2/9/09
My Write-ups: Ford Steering Box Rebuild / Ford Front End Rebuild and auto hubs replacement / Ford Rear Drum Brakes / Ford E4OD Cooler & Shift Kit mods, drain-refill procedures
Quote:
Originally Posted by kowboy1
Find someone else to take your third world anger out on...
Yep, but I'm the one with issues here.
  #9 (permalink)
Old 02-26-2011, 10:46 PM
Smile
When you say link do you mean something mechanical our wiring/electrical
  #10 (permalink)
Old 02-27-2011, 07:18 AM
L. Ward's Avatar
1990 Ford F-250
If the motor is running, but the window isn't moving, you need a set of these, available at your local Autozone or Advance in the "Help" section. They cost about $6 and go inside the gear assembly. Follow the instructions above to remove the motor/gear assembly, take the gear assembly apart, clean out the remains of the old plugs, regrease and put it back together.
74410
Type : Window Regulator Gear Plugs
Make : Ford 2006-65
Brand : Dorman - HELP! - Carded
__________________
  #11 (permalink)
Old 02-27-2011, 10:26 AM
Cool man thats what I was thinking was a gear issue or regulators thats sounds awesome I'm going to try that...will let you know how it goes
  #12 (permalink)
Old 03-09-2011, 07:48 AM
charlessocccer charlessocccer is offline
charlessocccer is starting off with a positive reputation.
First, Great informational guide, second, does all this apply to a 94? i would assume so, but just want to check before i start tearing into my window/door
Thanks!
  #13 (permalink)
Old 03-09-2011, 08:08 AM
subford's Avatar
The door would be the same but the wiring may differ some but would be close.
__________________
subford@gmail.com
  #14 (permalink)
Old 03-09-2011, 04:59 PM
ok, great thank you.
Thank you everyone for the write-ups, it gives me the drive to finaly get it fixed.....ive just dealt with my window hardly working sine June lol
  #15 (permalink)
Old 03-30-2011, 07:10 PM
viker123 viker123 is offline
1997 Ford F-150
viker123 is starting off with a positive reputation.
Hey guys,
Whats the deal if your window went up, but now refuses to come down? When I toggle it up, I hear the motor respond, but no noise when I hit the down side of the button. Had a spare button assembly so switched out and same thing. This is driver's side window only. Passenger side works fine and it did this suddenly. Put it up two days ago in rain and now will not open.
Thanks
1997 F150 Eddie baur ext. cab
Tags
250, 92, 95, 97, component, electric, f150, ford, motor, passenger, power, regulator, replacement, truck, window, windows, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
