Excursion on boggers build up - Ford Truck Enthusiasts Forums
Old 02-12-2011, 09:47 PM
Dubbs19s Dubbs19s is offline
Dubbs19s has a good reputation on FTE.Dubbs19s has a good reputation on FTE.
I decided to start a new thread with a better title for my build up, so it will be easier to find for reference later.
quick refresher
putting this stuff
on that
Ok, so I finally got some time to do some work on the excursion and superduty.
First thing was to get the duty a bit lower and easier to work on so the boggers came off
no more V10 vs Diesel debate....this 5.4 with 5.38 gears and 32" tires will out pull any of you hahah
anyways on to teardown
lots of fender clearance by the way
Lots of water in the flares..maybe need a drainhole
The front end parts are an easy swap so i didnt take too many detailed pics, just mark and cut away the fenders. I went way above the recomended line by bushwacker to try to force the flares up and back a bit for more front tire clearance.
everything was heavily coated with rustcheck before the flares were bolted on
how do you like my rusted away side steps
This bracket that holds the front spoiler under the bumper is actually welded to the front spring hanger..it will need to be torched off at a later date
front end done beside the picked over superduty
started on the back and ran into problems
went to take the rear bumper off and the there are some studs tacked to a piece of sheetmetal to keep them from turning. The sheetmetal had rusted so bad it broke and i had to end up cutting one side of the stock bumper bracket off to get the bumper off. Then I went to remove the trailer hitch and ford somehow screwed a bolt with a perfectly round head into the frame...I guess it is for safety, but i had to drop the gastank and grind the heads off them to get the hitch off.
After that, we were exhausted so tomorrow we'll start working on cutting the rear fenders and seeing if the rear bumper will even fit...the rear section of excursion frame looks different then the f350s
Old 02-12-2011, 10:27 PM
02xxx 02xxx is offline
02xxx is starting off with a positive reputation.
looks like fun!!!
Old 02-12-2011, 10:48 PM
ScaldedDog's Avatar
ScaldedDog ScaldedDog is offline
ScaldedDog has a great reputation on FTE.ScaldedDog has a great reputation on FTE.ScaldedDog has a great reputation on FTE.ScaldedDog has a great reputation on FTE.ScaldedDog has a great reputation on FTE.
Oh yeah, I'm anxious to see this.
Mark
Old 02-12-2011, 10:59 PM
ZBIGBIG19TH ZBIGBIG19TH is offline
ZBIGBIG19TH is gaining momentum as a positive member of FTE.
Your f250 looks very sexy with those wheels on.
Brakes my hart looking at the EX being butchered.
you had side steps?
Old 02-13-2011, 12:18 AM
i eat hybrids's Avatar
i eat hybrids i eat hybrids is offline
i eat hybrids has a very good reputation on FTE.i eat hybrids has a very good reputation on FTE.i eat hybrids has a very good reputation on FTE.
Why are you taking everything from the SD and putting it on the x?
Old 02-13-2011, 09:01 AM
Quote:
I needed a bigger cab and wanted a bigger engine ( ex has a V10, duty has a V8)
Old 02-13-2011, 09:14 AM
High Intentions's Avatar
High Intentions High Intentions is offline
Mod Specialist ;)
High Intentions has a superb reputationHigh Intentions has a superb reputationHigh Intentions has a superb reputationHigh Intentions has a superb reputationHigh Intentions has a superb reputationHigh Intentions has a superb reputationHigh Intentions has a superb reputationHigh Intentions has a superb reputationHigh Intentions has a superb reputationHigh Intentions has a superb reputationHigh Intentions has a superb reputation
I think it will look bada$$.
Old 02-13-2011, 09:36 AM
officer131 officer131 is offline
officer131 has a great reputation on FTE.officer131 has a great reputation on FTE.officer131 has a great reputation on FTE.officer131 has a great reputation on FTE.
I quote from the movie Office Space "that sure is a lot of flare."
Looks good so far, cant wait for the end product.
Old 02-13-2011, 04:19 PM
What are you gonna do with the duty?lol
Old 02-14-2011, 08:17 AM
wpnaes's Avatar
wpnaes wpnaes is offline
FTE SoCal Chapter LDR
wpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputation
Looks great, keep the pics comings, i'll be munching on the popcorn.
Can you put the license plate over the roller fairlead - would look a bit better?
Old 02-14-2011, 08:22 AM
Ranger431's Avatar
Ranger431 Ranger431 is offline
Ranger431 is starting off with a positive reputation.
Love the front bumper - custom made or did you buy it somewhere?
Old 02-14-2011, 08:25 AM
don't worry....the plate isn't staying there.
The bumper is made by Alien Patrol
Old 02-14-2011, 09:48 AM
jeeplj8 jeeplj8 is offline
jeeplj8 is gaining momentum as a positive member of FTE.
What is different on the rear bumper mount? The bumper itself is the same part number from Ex to Super Duty, is it just the mounts that are different?
Old 02-14-2011, 05:26 PM
Quote:
There is a rear crossmember about 3" away from the rear of the frame that wasnt there on the superduty..thats whats giving me the problem
Old 02-14-2011, 09:08 PM
A few more progress pics....I didnt take too many, I guess I was too busy
Laying out where the rear fender needed to be cut out for the flares and my rear bumper
Cut out
Inner steel fender pie cut and bent out of the way....this will be sealed up at a later date to prevent mud/dirt/water from getting up inside
That's all i managed to take for pics of the swap....but look what I found inside the jack compartment of my ex-police excursion
Strobe light power supplies....nice
5.4 to 6.8 V10 swap Dubbs19s Modular V10 (6.8l) 45 04-20-2016 11:03 PM
Installed Explorer Overhead Console mdula 1987 - 1996 F150 & Larger F-Series Trucks 40 11-02-2015 10:31 PM
wrecked 4X4 F150 Build Thread Staveys150 1987 - 1996 F150 & Larger F-Series Trucks 74 03-23-2014 07:03 PM
Problems aligning running boards-pics jrockdiddy 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 12-11-2012 10:41 PM
Help! What is this gauge for? packrat56 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 09-13-2012 11:36 PM
Tags
2000, 2001, bogger, bolt, build, builds, buildup, bumper, cut, excursion, fender, ford, package, pattern, pic, rear, tire, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
