Excursion on boggers build up
Old 02-15-2011, 07:10 AM
SkySkiJason's Avatar
SkySkiJason
SkySkiJason is online now
Received 1,891 Likes on 1,142 Posts
Subscribing! Anxious to see how the flares work out back there.
Thats gonna be one fun X!
Old 02-15-2011, 07:30 AM
bcrewcaptain's Avatar
bcrewcaptain
bcrewcaptain is offline
looks great...those strobe packs can be fun at parties...
"lick your fingers and hold these wires!"
Old 02-16-2011, 07:02 PM
RSQ4x4's Avatar
RSQ4x4
RSQ4x4 is offline
Keep those pictures coming!!! I have been thinking about going with Bushwackers for some time.
Old 02-18-2011, 09:40 AM
Dubbs19s's Avatar
Dubbs19s
Dubbs19s is offline
Got around to taking some pics since I ( by I, I mean the rain...crazy weather up here....+7 and rain today, -9 tomorrow) washed the truck
don't worry, the plate isnt going to stay there long
Pic of the back with the sides of the body cut for the bumper. Haven't had time to work on the bumper mounts either
Pic of the cut flare for the rear door. I marked it with some fineline masking tape and cut down the center of it with a jigsaw( which cut it like butter). I should have used something a bit thicker because they still touch when the door is closed...i'll just have to do another skim pass on one side. Notice the piece of flare on the door only has 1 screw so far...the body line must be a bit different because the supplied screws would not reach the body. i have some longer screws that should work. I hope to work on it 1 day this weekend
Pic of the bracket that needs to be cut off
one last detail...the Excursion on the driver fender needed to be removed...because the ends of the badge are angled..the one on the passenger side did not need to be removed
I have a shop booked on tuesday to do the suspension swap...pics of that shortly
Old 02-19-2011, 08:06 AM
TYZ78F150's Avatar
TYZ78F150
TYZ78F150 is offline
Dubbs,
Do you plan to swap axles from the SD to the X to get the lower gears?
Old 02-19-2011, 08:16 AM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
Some 320G on a bondo block will open up that gap in the rear flares easy and nicely.
Old 02-19-2011, 08:21 AM
1975StroppeBaja's Avatar
1975StroppeBaja
1975StroppeBaja is offline
Subscribing. Looks like a fun build!
Old 02-19-2011, 08:31 AM
wpnaes's Avatar
wpnaes
wpnaes is online now
Before you completely remove the tab for the bumperbar, consider adding a tow hook (this one is off the rear of a school bus). I only cut the piece that was parallel to the ground leaving the vertical piece to bolt the hook to.
Old 02-19-2011, 09:19 AM
Dubbs19s's Avatar
Dubbs19s
Dubbs19s is offline
Originally Posted by TYZ78F150
Dubbs,
yes, we're not even going to unbolt them from the leaf springs
Thanks for the tip..
Interesting idea...I will keep that in mind
Old 02-19-2011, 09:28 AM
fordboy67's Avatar
fordboy67
fordboy67 is offline
Looks like fun, I'll be watching!
Old 02-20-2011, 06:17 PM
Dubbs19s's Avatar
Dubbs19s
Dubbs19s is offline
Had some time to work on the Excursion today.
Thanks to Shelby for lending us her nice spot in the garage
There is a body seam in the wheelwell that has to go
trimmed, folded over and painted
Spent some time working on the fitment of the flares around the door...they sprung a little bit when I cut them
To add a bit of rigidity to the flares, I decided to fill them with spray foam...this should also keep them from filling with mud
expanded and trimmed
masked for paint ( rocker guard)
Painted. This also keeps you from seeing white between the flare sections
soon.........
Old 02-20-2011, 06:20 PM
bcrewcaptain
looks good...my .02
spray some bedliner/undercoating over those ends if you're not going to do a full cap on them. That foam can be worse than mud when it gets wet, it holds the water in the air pockets. I had to deal with some rocker panels/nerf bars somebody had filled with the stuff, it was BAD after a year.make sure it's 100% waterproof.
  #28
Old 02-23-2011, 01:49 PM
Dubbs19s's Avatar
Dubbs19s
Dubbs19s is offline
Ok , got lots of pics but the mostly turned out blurry, I must have been shaking with excitement.
poor old duty getting ready for surgery.
Front axle out
Lifted front end installed in the EX
Rear axle out
Stock front end in duty..how do you like the nice chrome grille
Lifted rear in the EX
stock rear axle waiting to go up
Tires and wheels on
The rear of the excursion is alot heavier than the dutys. Most EX lifts have a bit more lift in the rear to compensate for the extra weight, so I put my stock F350 3 5/8ths block back in. in order to keep my shocks, the shock mounts were loosened and rotated up until they would bolt in
I stole the double cardon joint driveshafts off of the superduty to eliminate driveline vibration ( the ex has just single Ujoints at each end of the shafts. Also worth mentioning, I have a 6.0 powerstroke front driveshaft in, as it is 1 1/2" longer than the gas engine shafts....getting a used one in the scrap yard is alot cheaper then ordering a whole new shaft.
Crash bar brackets hit the tires when turning...so byebye
also not pictured, i had my custom exhaust put on the excursion, but the tailpipes needed to be cut off because they would not clear the gastank.
Ok took some quick pics outside
home beside the escape
Went to the car wash to clean it up a bit, then out onto the lake for some pics...also notice the plates in the right spot and winch cover installed
yes, it it taller than that apartment building
still lots of work to do, like wire up my winch, lights and front locker , then fit the rear bumper and get some new tailpipes made up...but i'm pretty happy with how it turned out so far.
  #29
Old 02-23-2011, 03:09 PM
az2ny2008's Avatar
az2ny2008
az2ny2008 is offline
that looks sick man nice work
  #30
Old 02-23-2011, 03:20 PM
fordboy67's Avatar
fordboy67
Looks sweet! Nice job. A suggestion on the license plate....bolt a set of clips to the back of the plate (like ones used to hold a broom in the closet) then simply clip it to the rollers on the winch. It works slick, just pop it off when you need to winch...obviously someone else
Quick Reply: Excursion on boggers build up
