Excursion on boggers build up - Page 5 - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
  #61
Old 03-26-2011, 10:36 PM
fordboy67's Avatar
fordboy67 fordboy67 is offline
fordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant future
Quote:
Originally Posted by Dubbs19s View Post
My best friend has the fab skills...I just tell him what I want..hahaha
Sounds like a good friend to have
  #62
Old 03-26-2011, 11:42 PM
Kevn Kevn is offline
Kevn is starting off with a positive reputation.
I feel all warm and fussy inside Haha. Its nice to see other people liking my hard work.
Im Dubbs buddy in case it isn't obvious. I should have joined this forum long ago as Ive been driving Ford Trucks for years.
  #63
Old 03-27-2011, 08:27 AM
fordboy67's Avatar
Welcome, and again nice work!
  #64
Old 03-29-2011, 07:52 PM
herojeep's Avatar
herojeep herojeep is offline
herojeep is gaining momentum as a positive member of FTE.herojeep is gaining momentum as a positive member of FTE.
Found your build first on Pirate. Great to see you hear also. Looking good!
  #65
Old 03-29-2011, 11:01 PM
Quote:
Originally Posted by CanadianSmokie View Post
Liking the rear bumper!
Was this a custom build? If so, did you make templates? Would be interested in one for my Ex.
Again, nice job on the build..
Would you be willing to cut the rear sheet metal and add bushwacker flares?
  #66
Old 03-30-2011, 08:25 AM
CanadianSmokie's Avatar
CanadianSmokie CanadianSmokie is offline
CanadianSmokie is gaining momentum as a positive member of FTE.CanadianSmokie is gaining momentum as a positive member of FTE.
Have thought about it... I have some 3/8" industrial rock crusher belting that I have cut and ready to attach for flare/mudguards for now. Was more interested in the general layout for the bumper to be able to have one custom made for my application... ie: integrated receiver, tire carrier, fuel can carrier.
  #67
Old 03-31-2011, 07:13 PM
ro11ovr ro11ovr is offline
ro11ovr is starting off with a positive reputation.
Thats a good lookin Ex.
  #68
Old 04-16-2011, 10:55 PM
Dubbs19s Dubbs19s is offline
Dubbs19s has a good reputation on FTE.Dubbs19s has a good reputation on FTE.
Time to update my build thread
We've done a couple of minor and major mods to the Ex over the last few weeks , so i'll start with the minor
Light flex tests showed the tires rubbing the metal flap in the rear wheelwell, so that had to go
I layed out a line just below a welded seam in the wheelwell, and cut it out.
the cut piece
Also, I took off the 10 pound counter weight from under the body...I'm heavy enough as it is
Now for the major
Since we took off the rotten side steps and lifted the EX a total of 14"..it has been a challenge to get in, So Kevn and I started to build some nice side steps/rock rails
We started by drilling out some factory holes to accept larger bolts
took the exhaust hangers off and banged out the studs
and drilled out for larger bolts
Bolting the mounting plates to the frame...lots of room to work
We also removed the heavy exhaust heat shield...all it will do it trap mud up against the body
Time to bend some pipe
Basic shape of the rock rails
Supported under the truck, Making the support arms
Arms welded...holding itself up
Here are the rock rails ....all tacked together
Step plate...all the holes layed out for dimple dies
and trimmed to fit
Unfortunately, I forgot my camera when we went to drill out the holes, press the dimple dies and finish welding the rails, but here they are mounted under the EX
  #69
Old 04-16-2011, 11:08 PM
BlueHell BlueHell is offline
BlueHell is starting off with a positive reputation.
I really dig those rails! You should make some more and sell them!
  #70
Old 04-16-2011, 11:22 PM
Quote:
Thats the plan
  #71
Old 04-17-2011, 08:29 AM
fordboy67's Avatar
Nice rock rails!
  #72
Old 04-17-2011, 09:28 AM
TYZ78F150 TYZ78F150 is offline
TYZ78F150 is gaining momentum as a positive member of FTE.
Those canadians got some real fab skills man I tell ya!!
  #73
Old 04-17-2011, 05:13 PM
Quote:
Thanks alot
  #74
Old 04-18-2011, 11:43 AM
hkaiser83 hkaiser83 is offline
hkaiser83 is gaining momentum as a positive member of FTE.hkaiser83 is gaining momentum as a positive member of FTE.
Ohhhhhh I want some!!
  #75
Old 04-23-2011, 05:18 PM
A pic of my other ride...just got her all waxed up and ready to go for summer
5.4 to 6.8 V10 swap Dubbs19s Modular V10 (6.8l) 45 04-21-2016 12:03 AM
Installed Explorer Overhead Console mdula 1987 - 1996 F150 & Larger F-Series Trucks 40 11-02-2015 11:31 PM
wrecked 4X4 F150 Build Thread Staveys150 1987 - 1996 F150 & Larger F-Series Trucks 74 03-23-2014 08:03 PM
Problems aligning running boards-pics jrockdiddy 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 12-11-2012 11:41 PM
Help! What is this gauge for? packrat56 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 09-14-2012 12:36 AM
Tags
2000, 2001, bogger, bolt, build, builds, buildup, bumper, cut, excursion, fender, ford, package, pattern, pic, rear, tire, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
