Excursion on boggers build up - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 02-25-2011, 01:47 PM
3fingervic 3fingervic is offline
3fingervic is starting off with a positive reputation.
Poor Super Duty is right. It looks like a stud horse that was neutered.
  #47
Old 02-25-2011, 02:50 PM
Vijay's Avatar
Vijay Vijay is offline
Vijay is gaining momentum as a positive member of FTE.
nice, time for some Rustoleum!!!!
  #48
Old 02-25-2011, 06:47 PM
LunaticSVT LunaticSVT is offline
LunaticSVT is gaining momentum as a positive member of FTE.
What size lift was on the SD? Just curious.
  #49
Old 02-25-2011, 11:33 PM
Dubbs19s Dubbs19s is offline
Dubbs19s has a good reputation on FTE.Dubbs19s has a good reputation on FTE.
Quote:
It had a 6" ICON all spring lift
  #50
Old 03-12-2011, 05:35 PM
I had some time today to tackle some of the smaller jobs that needed to be done. I put some trim pieces back on the Excursion and pulled all the wiring I need out of the superduty.
I also pulled the transfercase skidplate off the F350
And put it on the Excursion
I also put the front bumper on the F350 so it doesn't look like its ready for the scrap yard
I've done a bit of highway driving with it and I am very happy with the performance of the V10. I am able to cruise at 1800-2000rpm ( 90-100 km/h) in overdrive with alot less throttle and I can actually accelerate without it kicking down
  #51
Old 03-13-2011, 07:54 AM
tdappleman tdappleman is offline
tdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to all
Looks great - nicely done!
  #52
Old 03-15-2011, 11:38 PM
I hauled some steel to the scrapyard and I got the weight of the excursion. So , with me( 150 pounds) the factory spare ( which is useless weight now)and 1/4 tank of fuel, the EX weighed 7740 lbs. That is about 550 pounds more than my duty....but the Ex still doesn't have the rear bumper, the rock sliders and a full tank of fuel. I Imagine it will be really close to 8000 lbs when finished and full of fuel
  #53
Old 03-26-2011, 08:00 PM
Bumper time!
found some time this weekend to work on the Excursion
thanks to my pal kevin and the yellow liftcart...we got the bumper in place and figured out how we were going to mount it
We ended up using a factory 1/2" hole, and enlarged 2 smaller ones
To get the bumper to fit, we had to notch the bottom to fit around the gastank
and to get at the bolts, we had to cut an access hole behind the license plate
It's on ( sorry this one is a bit blurry)
Its sitting back a bit farther then we had it on the superduty to offer a bit more protection to the rear doors and glass...it was more like a rollpan on the truck
We are going to make small caps to weld on the bumper to bring it flush with the flares
Of course there are no towhooks or lights yet...we just wanted to get it mounted for now and tackle the other stuff another day
  #54
Old 03-26-2011, 08:37 PM
fordboy67's Avatar
fordboy67 fordboy67 is offline
fordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant future
Looking good, looks like a fun project!
  #55
Old 03-26-2011, 08:49 PM
CanadianSmokie's Avatar
CanadianSmokie CanadianSmokie is offline
CanadianSmokie is gaining momentum as a positive member of FTE.CanadianSmokie is gaining momentum as a positive member of FTE.
Liking the rear bumper!
Was this a custom build? If so, did you make templates? Would be interested in one for my Ex.
Again, nice job on the build..
  #56
Old 03-26-2011, 08:53 PM
Agian, nice job on the build..
Yes it was a custom build, and no we didnt make any blueprints, but if needed, we could just measure mine and go from there...or build anything you want.
  #57
Old 03-26-2011, 08:55 PM
fordboy67's Avatar
Looks as if you have some serious fabrication skills, you should build/sell bumpers and winch mounts.
  #58
Old 03-26-2011, 08:56 PM
PM me with an approx. quote on one similar to yours...
  #59
Old 03-26-2011, 08:57 PM
Quote:
My best friend has the fab skills...I just tell him what I want..hahaha
  #60
Old 03-26-2011, 09:13 PM
I let him know and I will get back to you
5.4 to 6.8 V10 swap Dubbs19s Modular V10 (6.8l) 45 04-20-2016 11:03 PM
wrecked 4X4 F150 Build Thread Staveys150 1987 - 1996 F150 & Larger F-Series Trucks 74 03-23-2014 07:03 PM
The "Big Ford" mod Dubbs19s Excursion - King of SUVs 3 05-29-2012 07:54 AM
The new F150 project Staveys150 1987 - 1996 F150 & Larger F-Series Trucks 23 08-21-2011 11:02 PM
Superduty to excursion suspension swap Dubbs19s Excursion - King of SUVs 2 12-19-2010 06:41 AM
Tags
2000, 2001, bogger, bolt, build, builds, buildup, bumper, cut, excursion, fender, ford, package, pattern, pic, rear, tire, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
