transmission code "G" - Ford Truck Enthusiasts Forums
Old 03-11-2003, 03:41 PM
fordxxx fordxxx is offline
fordxxx is starting off with a positive reputation.
Is a transmission code "G" in a '72 F100 a C4?
Thanks
Old 03-11-2003, 03:45 PM
BB's Avatar
BB BB is offline
BB is starting off with a positive reputation.
G is the code for an automatic, doesn't specify which one.
Barry
Old 03-11-2003, 03:51 PM
If I have a 302 would it be a C4 or could it be a C6. Basically I'm trying to figure out what tranny I have. I always assumed it was a C4 but now I want to order a new torque converter so I have to be sure.
thanks
Old 03-11-2003, 04:17 PM
BB's Avatar
BB BB is offline
I thought they were all smallblock C6's by then but check the pan shape to be sure.
Old 03-12-2003, 09:58 AM
Thanks BBB. I crawled underneath last night and confirmed that it is a C4, (not a C6) thanks to the pictures that you directed me to. The cover is rectangular (with no notch) and there are 11 bolts holding it on.
Old 03-12-2003, 10:55 AM
BB's Avatar
BB BB is offline
Thanks for replying back!
Then they must have been all smallblock C6's starting in '73.
Barry
Old 03-12-2003, 07:28 PM
1968F250LWB 1968F250LWB is offline
1968F250LWB is starting off with a positive reputation.
Quote:
Another easy way to tell is if it has a removable bell it is a C4. If the bell is a molded part of the transmission it is C6
3 speed gear ratios 1966f250 1961 - 1966 F-100 & Larger F-Series Trucks 3 02-22-2016 08:26 AM
Transmission type texanrick 1973 - 1979 F-100 & Larger F-Series Trucks 5 04-24-2015 10:38 AM
Date codes 0n 57 "G" Heads ydaveitsu Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 2 03-07-2005 02:14 PM
1995 E150 Transmission Code G IceWagon 1968-2013 Full Size Vans 3 01-29-2005 04:27 PM
What trany? jpb222 1973 - 1979 F-100 & Larger F-Series Trucks 22 06-03-2001 08:11 PM
Tags
1996, c4, c6, code, ford, gm, pan, parts, picture, ram, shape, shapes, trans, transmision, transmission, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
