Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 02-12-2011, 06:12 PM
Fireman_dave Fireman_dave is offline
1990 Ford F-350
Fireman_dave is starting off with a positive reputation.
wmo
i assume from reading wmo is waste motor oil, i have a 7.3 idi diesel, and i am a maint man at a foundry, i take care of 30 diesel forklifts serviceing them every 200hrs , with a service it gets an oil change and the trans fluid changed..and it all gets dumped into a 55 gal drum, there might ever be a bit of hyd oil in there too....how would this combo do?, i know when i change fuel filters on the diesels i always use tranny fluid to fill the filter
  #2 (permalink)
Old 02-12-2011, 08:18 PM
bradyracing bradyracing is offline
Garage is empty, add now
bradyracing is starting off with a positive reputation.
I'm just curious. When you change filters on a diesel, you always fill the filter with tranny fluid? Why not fill the filter with diesel?
__________________
2004.25 F250 CC Powerstroke on B100, 220K miles
1992 F350 CC SRW 4x4 Cummins powered, on B100
Biodiesel maker
http://community.webshots.com/user/b...host=community
  #3 (permalink)
Old 02-13-2011, 07:52 AM
1990 Ford F-350
thats the way i was taught with a diesel....supposedly atf has some real good solvents in it and with it being thicker than diesel it will clean out the injectors...is this true or not.....i dont know.....but i always have done it
  #4 (permalink)
Old 02-13-2011, 12:01 PM
armstrongfordtrucks armstrongfordtrucks is offline
1975 Ford F-250
armstrongfordtrucks is gaining momentum as a positive member of FTE.
ATF I have heard is the best diesel injector cleaner available. I run WMO in my 2000 7.3, however I would run nothing but ATF if I could get my hands on it. I believe it is the same viscosity as diesel. WMO is to thick at 30* to start the truck outside unless you keep it plugged in. I am in no way recommending you run anything except diesel in your truck though. Could trash your fuel system. I only have logged 10,000 miles so far, don't know the consequences yet.
__________________
ARMSTRONGFORDTRUCKS
2000 F-350, XLT, CC, 4X4, AUTO. 5" STRAIGHT THRU, 6637, DP TUNER, stock, hi idle, 60 tow, decel, 80 econo, 120 race, BED LINER, GAUGES. FRESH RUST FREE FROM HUSTON TEXAS.
Tags
73, biodiesel, diesel, filter, ford, idi, wmo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
