Universal joints ...pinion angles
Thanks for all the responses. I'm at 2 and 2 degrees now . My vibration starts at around 70. First thought it was tires so spun balanced off and on the truck. No help. This last set made it 2900 miles before they went metal to metal. Going to recheck angles this week. Is it possible the springs wrap under increased wind load ?
One of the biggest reasons for rear u-joints to fail prematurely is over tightening the u-joint clamps. It is easy to over tighten them which distorts the caps. I can't give you a torque spec but they only need to be tight enough to not come loose. It is pretty common to really crank down on them.
i may hear some flak for this, but, in my opinion the angle should be more like 6 or 7 degrees. 2 degrees is so close to straight that bearings are not spinning correctly in caps. if rear is twisting under load, this would cause joints to possibly be dead straight. not good. i would check the driveshaft for trueness and balance. it has weights on it. possible one has left the shaft.
I have been told the same by a local Mustang racer as well. He is running 6 degrees down on the pinion, 2 degrees down on the transmission. The first thing I did was pull the drive shaft and had it balanced and checked for straightness. The weights are still on. Thanks.
Bernie
is yoke tight on pinion shaft? is pinion bearing and/or shims correct for rear? does u-joint fit correctly on both ends? unless you are beating the water out of it, you are either crushing the caps, (like all above posts say), or--something is walking under pressure in rear. vibration says movement. (bearing, yoke, shaft movement that appears at higher speeds) far stetched, but possible--are carrier bearings wearing out and causing drag?
