Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 03-20-2003, 03:26 PM
79 Pulling Ford 79 Pulling Ford is offline
79 Pulling Ford is starting off with a positive reputation.
Building a 460 for a pulling truck
A guy who we pull with actually got a hold a set of the EX's. I talked to the manufacturer of the heads and the flow numbers are no secret. He told me they flow pretty much the same as the aluminum EX's. The flow numbers are on the website. Another question for you. Where you pulling and what class. Around my neck of the woods the aluminum heads are not allowed.
  #17 (permalink)
Old 03-20-2003, 09:28 PM
greenhighboy's Avatar
greenhighboy greenhighboy is offline
greenhighboy is starting off with a positive reputation.
79 Pulling Ford were do you pull? I am running in a class were I have to run a cast intake and iron heads. The classes above me have to run iron heads also. I'm running a CJ intake and DOve heads that have had alot of work done on them. This set up seems to do pretty good. I would love to stick a Victor on it and see how it ran.
Dennis
1999 F-350 Powerstroke
1977 Highboy 429 4-speed 35"s
1972 Ranger on a 1978 F-250 4x4
frame 466 630HP Pulling Truck
  #18 (permalink)
Old 03-20-2003, 10:07 PM
I pull in Indiana, Michigan ,and Ohio. The victor intake is killer. I know guys who have run the Stealth also and when they change to a Victor it is like night and day differance. I can not believe that they limit you to a cast intake. That puts the hurtin on the old horsepower, but it also would be kind of fun to see what you could do with it. I always love a challenge.
  #19 (permalink)
Old 03-21-2003, 10:45 AM
Jamey L. Hanis Jamey L. Hanis is offline
Jamey L. Hanis is starting off with a positive reputation.
I posted this as a new thread in the forum, but I found a 1969 429 out of LTD. The engine has a two-barrel and Dove A heads. Is there anything useful off of this engine (block, heads)? It's a California car complete. It ran when they parked it. I can get the entire car for $275.
So far, I'm learning everything I know about 460's and 429's from this forum, what is the difference between a Dove-A head and a Dove-AA head? Which is better?
  #20 (permalink)
Old 03-21-2003, 10:49 AM
qtrmiler qtrmiler is offline
qtrmiler is starting off with a positive reputation.
BUY THE CAR!!!!! Everything is good except the intake!
  #21 (permalink)
Old 03-21-2003, 12:26 PM
I second that. You better jump on it. A running 460 in my neck of the woods goes for $300-$400 dollars.
  #22 (permalink)
Old 08-20-2007, 12:25 PM
Redneck-Cowboy's Avatar
Redneck-Cowboy Redneck-Cowboy is offline
Redneck-Cowboy is starting off with a positive reputation.
Jamey, this is Chris Bouc from over in Weston, I know this is a lil off the subject but it's kinda the same. i know you run regular modified w/ ur pickup sumtimes, can you gimma a quick run down of the rules? Me and a couple of friends are building a modified this winter and I already have my 460 ready to be built, i just wondered what limitations there were in the modified for the the engine if any other then forced induction. Also hitch where abouts, thanks
__________________
Redneck-Cowboy
86 F-150 4x4, 4spd w/ a 300, Headers, 500 cfm 4-barrel, D.U.I or "H.E.I" ignition/dist., mild cam with chevy rockers, steel timing gears, decked the block and head .015, bored .060, true dual straight 2.5" all the way back ( a little to snappy, but frickin LOUD)
  #23 (permalink)
Old 08-20-2007, 03:31 PM
The Freak The Freak is offline
The Freak is starting off with a positive reputation.
I'm assuming you are talking about rules for the Street Mod classes at local pulls and not the rules for the NE Power Pullers.
Basically, the only thing I ran into this year was that places were not allowing nitrous, which most likely would not affect you or most people for that matter. Hitch height usually ranges from 26-30 in. I have not run into any local pulls that use a % of wheelbase on hitches. Tires must be DOT. Besides that pretty much anything goes with engine size and mods.
Hope that helps you out.
  #24 (permalink)
Old 08-20-2007, 04:35 PM
yup that's what I was looking for pretty much, you wouldn't happened to have that about 85 or 86 ford pulling truck called the "the freak" would ya? lol
__________________
Redneck-Cowboy
  #25 (permalink)
Old 08-20-2007, 04:48 PM
No, but it does have my intake, heads, rocker arms, pushrods and headers on it. Basically, now he needs to build a bottom end and put a different/better clutch in it.
What year of truck are you guys looking at building?? If it doesn't already have the 460 in it, you may have a little bit of work ahead of you, but it is a winter project so I'm sure you will be fine.
  #26 (permalink)
Old 08-20-2007, 04:52 PM
late 70's, it'll be a 351M/400 swap, no biggie other then motor mounts and some other samll issues. On that freak truck is he still running his TTB? I tryed pulling mine in stock and I cannnot for the life of me hook up to the track with it, I'd prolly be better off in modified so i could block and bind it up and get some weight on the front
__________________
Redneck-Cowboy
  #27 (permalink)
Old 08-20-2007, 10:11 PM
I can help you out with motor mounts. They are solid and will bolt right in to a late 70's F-250.
  #28 (permalink)
Old 08-21-2007, 06:35 AM
79superduty 79superduty is offline
79superduty is starting off with a positive reputation.
460 ford .com check it out
__________________
79 supercab f350 557ci.
  #29 (permalink)
Old 08-21-2007, 09:04 AM
I thought I'd just take the ones from the 460 and the ones from the 351M/400 and kinda set em on top of each other take a look at it and make something that'll bolt the 460 in, solid of course. I have my 460 outta a 79 econoline, it runs and I've never even looked at the engine, just offered him 200 for the whole thing and he said sold
__________________
Redneck-Cowboy
  #30 (permalink)
Old 08-22-2007, 04:32 PM
CBSuperduty's Avatar
CBSuperduty CBSuperduty is offline
CBSuperduty is starting off with a positive reputation.
I sure hope you are gonna build it some. I ran a fairly stock 460 last year and it was horrible. Put some money into it and you will be fine. Good luck.
__________________
CBSuperduty - Chris
2008 Dodge 3500, QCSB, 4X4, 6.7 CTD, Hand Shaker, No Mods Yet.......
1979 F250 2wd Pull Truck, 468CID
SOLD
2004 F350, RC, 4X4, 6.0 PSD, Torqshift, Various Mods.......
2002 F250, CC, 4X4, V10,
Tags
460 , 466 , build , building , ci , d0ve , ford , heads , hitch , motor , mpg , portosonic , pull , pulling , stock , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
