1949 F3 - Ford Truck Enthusiasts Forums
1949 F3
Old 02-12-2011, 02:21 PM
MAN_N_BLACK MAN_N_BLACK is offline
MAN_N_BLACK is starting off with a positive reputation.
1949 F3
Im getting ready to start working on my 49 f3. Its going to be a driver (not racer) just jump in anytime and drive. its going to have a 1980 351w with either a c4 or c6 not sure that yet. im looking at trying to keep close to the same ride height. im looking at converting the front to discs with the speedway kit. planing on running the 5 on 4.5 pattern. il have full moons so the pattern wont be seen. for the rear i either have a '86 ranger axle or i have a '79 cougar 9". the cougar is still a complete car and im parting out the ranger so im thinking on using that. any commets on this build.
also i was wandering is there a adapter kit to put a grant steering wheel on the stock steering colum
a few pics
Old 02-12-2011, 02:28 PM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
Wow that is a solid looking truck. Is there any rust in it anywhere?. I like a 351W if the flattie is not going to be used. It makes more sense than a 302. Unless that is what ya got.
Man In Black. That was Johnnie Cash's moniker. May he RIP.
Old 02-12-2011, 02:43 PM
there is a little bubbly rust on the rear fenders and little bit here and there but nothing to bad. it also has the factory grill gaurd in the back. i want to use that since its not common for people to use them. i paid $650 for the truck back in febuary of '08 just now starting to get in tho the project. im planning on useing the tires and moons that came with it just need different 16"rims that have the 5 on 4.5 pattern. also there is no bed in the truck so im trying to figure out what to do there. i got a bunch of that composite wood(grey in color) thinking that would look kinda cool
Old 02-12-2011, 03:02 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle Jeff and Nicolle is offline
Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.
Welcome to FTE,
I also have a 49 F3, I see you are from Iowa, Just wanted to say hello.
Old 02-12-2011, 07:50 PM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.
Nice looking truck. I personally advocate keeping things mostly stock. For your rear axle swap you will find that the 9 inch from 57 to 72 F-100 pickups is the correct width. You will then need to get axles with the bolt pattern you want and swap them into the housing. Why don't you want to go with 5 on 5.5 inch pattern?
Old 02-12-2011, 09:28 PM
GreatNorthWoods's Avatar
GreatNorthWoods GreatNorthWoods is online now
GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.
The Ranger rear should work okay and there is a Grant steering wheel adapter available for your steering column. Aftermarket 16 inch wheels with the 5 x 4.5 pattern are available although finding them in stock form might be tough. Good luck with the build!
Old 02-14-2011, 10:53 AM
steveFord49F3Pickup's Avatar
steveFord49F3Pickup steveFord49F3Pickup is offline
steveFord49F3Pickup is starting off with a positive reputation.
F-3
Good luck. I recently completed my F-3 that I started in 2004. Kept mine mostly stock except swapped out the rear end for a dana from a 72 Ford and found original stock 16" from a 52 F-250 to replace my 17" split rim widow-makers. Love the truck - can't wait for the snow and ice to melt
Old 02-14-2011, 11:22 AM
38 coupe
the main reason for useing the ranger rear end is this truck is a use what i got and buy as little as possible that being said the 4.5 kit is cheaper then the 5.5
ayone got a part number on that grant adapter?
Old 02-14-2011, 02:01 PM
tjdad62's Avatar
tjdad62 tjdad62 is offline
tjdad62 is gaining momentum as a positive member of FTE.
MIB,
I bought my disc kit from CPP and it was the same price no matter what the bolt pattern. Of course, the rotors are on back order right now so I haven't received it yet, but no difference in price.
Old 02-14-2011, 02:49 PM
Quote:
Originally Posted by MAN_N_BLACK View Post
anyone got a part number on that grant adapter?
I believe you want a Grant 4297 but double check the number before you order.
Old 02-14-2011, 07:40 PM
may i ask what cpp is?
Old 02-14-2011, 09:32 PM
Classic Performance Parts.
Disc Brake, Steering and Suspension Products for classic Chevy and Ford cars and trucks
Old 02-14-2011, 10:40 PM
ArmyFord's Avatar
ArmyFord ArmyFord is offline
ArmyFord is starting off with a positive reputation.
Welcome. Looks to be in good shape. It's nice to see more F3s out there. I have a 48 that I just got. I'm going with the Dana 60 swap with 16" rims from an F2.
Could you post a picture of the factory grill guard? I got a grill guard with mine and was wondering if it was factory. I am also thinking of using it. Does it look anything like this?
steveFord49F3Pickup,
Any insights to share on the Dana swap? I got mine from a 69 F250. Was it a straight bolt-in, or was there some fab work to do to do?
Old 02-14-2011, 11:01 PM
F100FE F100FE is offline
F100FE is starting off with a positive reputation.
That grille is from a Ford tractor. I have one just like it on my 601.
Old 02-14-2011, 11:09 PM
ArmyFord's Avatar
Interesting. The guy I bought it from said it was installed on the truck when he got it. Thanks.
Build Progress (So Proud) snook715 1948 - 1956 F1, F100 & Larger F-Series Trucks 413 11-02-2015 06:36 PM
1978 Ford F100 Ranger/Explorer Newbie quarkdude 1973 - 1979 F-100 & Larger F-Series Trucks 23 12-09-2014 09:21 AM
HB3 9005 LED Fogs Fox Fader 2004 - 2008 F150 11 05-04-2011 09:29 PM
168 194 906 921 LED Fox Fader 2004 - 2008 F150 3 04-22-2011 11:57 PM
Monster 337 ci flattie in '53 (pics) denverslim 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 02-09-2011 02:40 PM
Tags
1949, 49, axle, brake, disc, f3, ford, imghttpi120photobucketcomalbumso190regalmann001jpg img, inch, list, lock, parts, price, rear, swap, traction, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
