Power steering fluid flush?? - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 11-24-2014, 06:46 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
Print Wikipost
Old 02-12-2011, 10:34 AM
ramrod7373 ramrod7373 is offline
ramrod7373 is starting off with a positive reputation.
Took my truck into Big O to have tires rotated and they did a fluid check. They told me my power steering fluid needed to be flushed and drained. I have never heard of this. Want to charge me $99 for it. They said if I don't do it soon it will lead to pre-mature pump failure. What do you all think?
Old 02-12-2011, 10:49 AM
redman84's Avatar
redman84 redman84 is offline
redman84 has a good reputation on FTE.redman84 has a good reputation on FTE.
$99 to flush and fill a couple(if that) quarts of ATF? I hope you told them to just flush the space between their ears instead. It's not too hard to do. I've done with directions from here before but can't remember which line to disconnect. Kinda messy but not hard. Got ATF on my axle so I had to smell that every time I rolled down the window for a WHILE.
Old 02-12-2011, 12:04 PM
Iallwork's Avatar
Iallwork Iallwork is offline
Iallwork is gaining momentum as a positive member of FTE.
Mine was wining a bit then my power streering line blew off so the fluid got changed then. Kind of a messy way to do it. Oh well little bit of rust proofing from the salt in that spot. good idea to change it though. The line on the side of the pump is easy to get at. Not sure how to flush it other then drain what you can and fill it back up a couple times. Try doing a search for it on here.
Old 02-12-2011, 12:16 PM
Major Marvin's Avatar
Major Marvin Major Marvin is offline
Major Marvin is starting off with a positive reputation.
I've been wanting to do this as well, what is the best ATF to use? Synthetic?
Old 02-12-2011, 12:18 PM
pjwoolw's Avatar
pjwoolw pjwoolw is offline
pjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to all
I just pump out as much as I can out of the reservoir with a small lube pump. And fill with synthetic ATF. I just did it a couple of weeks ago for the third or fourth time. Kinda of a long process but I hate the mess of pulling down that low pressure hose.
Old 02-12-2011, 12:24 PM
KonaGrown's Avatar
KonaGrown KonaGrown is offline
KonaGrown is starting off with a positive reputation.
http://www.superdutypsd.com/power_steering_flush.php
This is for a superduty, but the procedure should be exactly the same. Just have to find the right line to disconnect and connect a hose to. Then turn the wheels from full lock to full lock (with truck jacked) keeping the reservior full until you have clean ATF fluid coming out.
Old 02-12-2011, 12:35 PM
pjwoolw's Avatar
Unless its been converted to Hydro Boost that procedure isn't possible. Good link though!
Old 02-12-2011, 01:44 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud of
If you want to flush it completely, you will have to disconnect the low pressure hose and it makes a bit of a mess. I would do like Pete said, pump the fluid out of the reservoir and refill it. That will get the majority of the fluid.. Of course, flushing the whole system wouldn't hurt
Old 02-12-2011, 02:27 PM
RRranch RRranch is offline
RRranch is gaining momentum as a positive member of FTE.RRranch is gaining momentum as a positive member of FTE.
Anytime a shop recommends a flush on ANYTHING, they are hurting for hours. And money. It's all a scam!!!!!! Don't buy into it.
Do like the others said and just disconnect the return hose. BUT also cut taht old return hose off the cooler down in your cross member. Install a new hose about 3 feet long and install a 3/8 inline transmission filter. With 3 feet of hose on it you can tie strap the filter in that gap between your wheel well and frame for easier replacements in the future. Just make sure to tie strap it clear of the fan too. Those filters are cheap. And use synthetic ATF like mobil 1 or something. If it's making noise now then type F should shut it up. That was some good stuff back in it's day. Ford called for it in all power steering systems through 91.
Old 09-30-2011, 03:54 PM
Bronco25 Bronco25 is offline
Bronco25 is starting off with a positive reputation.
Don't Mix Fluids
Type F and the Dexron type fluids (Mercon) are incompatible. The seal materials for the associated fluids are attacked if the wrong fluid is used. The source of most power steering leaks is that someone at one time put the wrong fluid in the system. This made it confusing for many years when Ford switched to Mercon for the transmissions yet kept Type F for the power steering systems up until 1995. If it says Type F, do not use Power Steering Fluid or Mercon/Dexron products.
Power steering fluid panteramatt Explorer, Sport Trac, Mountaineer & Aviator 6 10-20-2016 08:18 AM
2000 F250 5.4L Power steering pump flush beachcamperf250 1999 to 2016 Super Duty 3 05-21-2014 09:09 AM
Power steering flush: Royal Purple? Jesser02EX 1999 - 2003 7.3L Power Stroke Diesel 8 11-14-2013 11:24 PM
How Much Power Steering Fluid Do I Need? brc777 Ranger & B-Series 9 04-01-2012 07:57 PM
Quick question..does it matter what power steering fluid? ztmike 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 10-22-2009 04:08 PM
Tags
1997, 2006, 40, 4x4, atf, f15o, f350, fill, fluid, flush, ford, lariat, liter, location, power, powerstroke, steering, synthetic, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
