1996 Changing Heater Core - Ford Truck Enthusiasts Forums
Old 02-12-2011, 01:59 AM
rlay302 rlay302 is offline
rlay302 is starting off with a positive reputation.
How hard is it to change a heater core in a 1996 F-150. Is there any place I could see some pictures?
Old 02-12-2011, 02:41 AM
drjoe171 drjoe171 is offline
drjoe171 is starting off with a positive reputation.
Hi
I'd try the search function but do it specific for your year.
You'll get tons of answers all at once since it's not really a daily problem I see on here.
I spent an hour standing on my head removing bolts and mine never did come out.
Yes, best to get some good info for sure.
Old 02-12-2011, 05:02 AM
cj06's Avatar
cj06 cj06 is offline
cj06 is gaining momentum as a positive member of FTE.
Old 02-12-2011, 05:10 AM
Thanks cj06,
I found both of those very useful.
Old 02-12-2011, 09:45 AM
CClark56 CClark56 is offline
CClark56 is starting off with a positive reputation.
It's actually pretty simple, only took me an hours worth of time once I got the tools and the new heater core.
I know right now the hardest part will be getting the hoses off of the old heater core, what I did was make a slice up the hose and wedged a flat head screw driver around the sides to free it, a little tiny dab of WD-40 in the slice wouldn't hurt either.
Old 02-12-2011, 10:39 AM
raptor1971's Avatar
raptor1971 raptor1971 is offline
raptor1971 is starting off with a positive reputation.
Also make sure the gasket is good. I replaced mine last summer and come winter it was blowing cool air.It was blowing hot air out of the cover for the heater core. I took it apart last week and put sticky foam that my friend did not need to use when he did his 96 250. His heater core came with the foam from his part store, but mine from Oreilly's did not come with it. I read on here you can get the foam from a hardware store.
heater core rkmason Large Truck 2 12-09-2014 10:17 PM
Heater core rcraft 1967 - 1972 F-100 & Larger F-Series Trucks 2 03-30-2014 04:55 PM
Need seal for heater core. 4x4 Bart 1973 - 1979 F-100 & Larger F-Series Trucks 44 03-07-2014 01:39 PM
1996 heater core replacement perryau1996 1987 - 1996 F150 & Larger F-Series Trucks 12 03-11-2011 08:17 AM
Heater Core NoHeart2 1999 to 2016 Super Duty 3 10-28-2009 02:13 PM
Tags
1996, 96, change, changing, core, f150, f250, f350, ford, forum, heater, replace, replacing, truck, video
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
