Headlights pulsing, why??
Old 02-11-2011, 06:09 PM
armydude's Avatar
armydude
armydude is offline
I have noticed that my headlights pulse bright, dim, bright, dim....Why???
Is my alternator going bad? This is generally the first 45 minutes and i have no other issues anywhere. I have an 04 6.0 diesel.
Ideas? I have heard of an alternator wiring upgrade, anymore info?
THANX EVERYBODY!!
Old 02-11-2011, 06:38 PM
Excurvelle's Avatar
Excurvelle
Excurvelle is offline
Yes, the alternator and or regulator is going bad.
Old 02-11-2011, 07:00 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
..or you have a high resistance in the battery voltage monitor circuit back to the alternator. That was a very common on Ford's Contour and Cougars. Caused the entire lighting circuit to go dim..bright..dim...bright..., etc several times per second. The fix on those vehicles is to modify the wiring harness.
Old 02-24-2011, 07:39 PM
banshee_man_96's Avatar
banshee_man_96
banshee_man_96 is offline
Mine was doing this one time and i found that the wiring harness plug going into the top of the alternator had backed out just enough and was causing my light to go dim and bright like pulsing. Pushed the plug back down into the alternator and problem fixed. May be something to check but i hear alternator go out often on the EX. Maybe worth a try?
Old 02-25-2011, 12:15 PM
GregN's Avatar
GregN
GregN is offline
I just replaced my alternator (for the 3rd+ time) because of this. If you take it out and bring it in to get tested, it might not test "Bad". It is most likely the Voltage Regulator going out. The next thing you see will be the Battery light flickering on and off (if you're lucky). I got a nice replacement alternator (High Amp/Heavy Duty) from:
http://store.alternatorparts.com/6g-...lternator.aspx
I went through 2 NAPA Alternators within a year, so I wouldn't suggest those. The National Quick Start one lasted me about 60,000 miles and just went out two weeks ago (left me stranded at a gas station; no flickering, but lights were dim). A lot of people suggest just going with a Motorcraft from the Dealer or Parts Guy Ed; that alternator lasted over 100,000 so it can't be that bad.
GregN's Avatar
GregN
GregN is offline
Old 02-27-2011, 03:48 PM
TT66's Avatar
TT66
TT66 is offline
projectsho89, You wouldn't happen to know how they modified the wiring harness for the fix? I am currently seeing this same scenario in a Ford division vehicle.
shore
1997 - 2003 F150
04-17-2016 12:23 AM
briosan
02-24-2016 10:52 PM
Milwaukee1979F150
25
12-12-2015 02:05 PM
FarmingFord
1999 to 2016 Super Duty
12-10-2014 10:17 PM
sweetiepie1
08-17-2012 09:28 AM
Quick Reply: Headlights pulsing, why??
