High pressure oil pump
Honestly, I have know idea....I have had this problem for awhile now..Run it, gets hot, cut it off, it wont start back....Crank & Crank & Crank, no start....Last couple of times towed it to the garage got ready to work on it just as hunch turn key, truck fired right up.. FICM checks out fine, batteries check out fine, I am down to I have no clue, just reading to see what else i can put new on it.
http://www.bulletproofdiesel.com/Hig..._p/6000034.htm
Will this kit replace the STC fitting or is this for something all together different?
I suppose there is no way to know if the upgrade has been done without pulling the cover? I should have checked when I did the EGR/engine coolers!
If I do have the turbo off again can I lift the HPOP cover without pulling the intake manifold, or are the turbo pedestal bolts under the manifold?
on
I dont know about quicker either way take me about the same amout of time. the risk involed in doing it with the intake on is droping a bolt dwon in the rear cover of the engine. that sucks.
I would not reuse the pump cover gasket. there is a blue o-ring on the pump that can be reused if needed and undamaged.
I posted the other day of a crank, crank, crank and No start after the truck was warm. Everyone leaned towards the SCT. Went out this morning after 36 plus hours and still no start. I hooked up the programmer read the codes and got: 0261,0264,0267,0270,0273,0276,0279,0282,2614. In saying that, could it be the FICM or even the Cam Shaft Sensor with the 2614 code, headed to check voltage as soon as the help gets here. This issue has happened several times, as in 4, but usually always starts back after 12 hours or so, and always checks out good on the voltage, checked 47 to 48 volts as always....
