Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 02-11-2011, 05:27 PM
knapikmichael knapikmichael is offline
Garage is empty, add now
knapikmichael is starting off with a positive reputation.
blowing black smoke
how can i turn up my injectors to blow some black smoke on a 84 ford f250 6.9l diesel
__________________
94 SC 7.3 4x4 IDI DIESEL stock with e4od 355 gears 38" tires 96 f150 4x4 stock with e4od 4.11 gears with 36" tires
  #2 (permalink)
Old 02-11-2011, 08:45 PM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
1993 Ford F-250
Sycostang67 has a good reputation on FTE.Sycostang67 has a good reputation on FTE.Sycostang67 has a good reputation on FTE.
Get a pyrometer first or the only thing you will be blowing is your motor. It doesn't take much fuel to melt the pistons in a non turbo motor.
__________________
http://www.ford-trucks.com/user_gallery/tmp/159/159207.520.390
1993 F-250 HD XLT Lariat SC 4X4 7.3/5spd ATS WG turbo @ 12psi, 3" DP 4" straight exhaust, 5" stacks, Hypermax cowl induction, IP up 3 flats, DPS stage 1 injectors, GPR LED mod, Pyro/Boost guages-186whp 363wtq @ 10psi
1986 F-250HD XLT Lariat 4X4 6.9/T19, soup bowl mod, straight pipe.
  #3 (permalink)
Old 02-12-2011, 03:28 AM
rupejosh's Avatar
rupejosh rupejosh is offline
1994 Ford F-250
rupejosh has a very good reputation on FTE.rupejosh has a very good reputation on FTE.rupejosh has a very good reputation on FTE.
why is it you want to blow black smoke?all its going to do probably is give you bad mileage and a thinner wallet because of that.you wont see a huge power increase or anything like that i doubt.all black smoke is is unburned fuel.sycostang pretty much covered the other part.
  #4 (permalink)
Old 02-12-2011, 03:32 AM
Aune163rd's Avatar
Aune163rd Aune163rd is offline
A Half a meatball....
1987 Ford F-250
My Garage
Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.
When you get your pyrometer installed, make sure its as close to Cylinder number 8's part of the exhaust manifold as possible, the one in the back right corner if your looking at it from the front. The injection pump needs to be turned up, there are many threads on how to turn it up on the forums, just search google with: Turn up injection pump 6.9 Ford Forums
__________________
Quintin Aune BigBs'r #21 & Off. Slackmaster #31
1984 F250 6.9l N/A 212,000 miles Wrecked 26 Oct 11
1983 F-250 6.9l N/A 5" stacks 4 spd 166k miles(sold)
1990 F-350 7.3l IDI ZF-5(sold)
2000 F-250 6.8l Triton V10 195k miles(Fiance's)
1987 6.9l 4 spd 172k miles
  #5 (permalink)
Old 02-12-2011, 10:12 AM
snaponprofile's Avatar
snaponprofile snaponprofile is offline
1992 Ford F-250
snaponprofile is starting off with a positive reputation.
The more people blow black smoke, the more motivated tree huggers get in passing laws against those kinds of things. If you are set on turning of the IP, the others already covered what you have to do. Get a pyro and read on how to turn your IP up. I would start by turning it up 1/6 turn and then if your EGT's are fine do another 1/6 turn. You don't want to turn it up too much without a turbo.
__________________
1992 Ford F-250 XLT 7.3 IDI 115K, 4X4, ZF5 S5-47 w/ 12inch clutch and SMF, Banks wastegated sidewinder turbo, 6637, BB injectors, rebuilt IP w/ fuel turned up, 3 inch DP, custom 3.5 inch exhaust with 4 inch tailpipe, 285/75/16R Yokohama's on PSD alcoas. Rebuilt D60 w/ firestone airbags. 10.25 sterling rear w/4:10's LS, Three pillar gauges with pyrometer, boost, and transmission temperature. Onboard air w/ 400C Viair. 16K rated B&W trailer hitch. Sound-tracker CB w/ 4 ft firestik.
  #6 (permalink)
Old 02-12-2011, 07:19 PM
royzell royzell is offline
royzell is starting off with a positive reputation.
Quote:
He's right, and it isn't just tree huggers. If you look around there are already diesel pickup lobby groups worried about non-commercial diesel trucks being banned altogether.
In the Commercial world, you will never see a new semi pushing black like the old days, the laws are too stringent, and the technology too complex.
The current US government (which means all of North America) is pushing for even more restrictions in the commercial world, just wait for 'trickle down'.
__________________
88 F-250 ext cab, 7.3, C-6, 3:55, 4WD, - sold
84 Mercedes 300SD turbo-diesel(parts car also)
93 Honda Accord
77 Chev Class C Motorhome
and other rusty or rugged parts vehicles...
  #7 (permalink)
Old 02-12-2011, 07:31 PM
wreckinball's Avatar
wreckinball wreckinball is offline
1989 Ford F-350
wreckinball is gaining momentum as a positive member of FTE.
especially on the island here! i felt out of place when the truck had the old ip and smoked everywhere. California is usually the test bed for these kinds of laws and with them not emissions testing 1998 and older diesels, the more people that go around choking out people on the streets, the more they are inclined to change the testing year. Soon we all will have DPF units on the truck and cats. Friggin crazy but its the posts like this that scare me and make me wonder why you want to "roll coal." Thankfully he thinks its turning up injectors so i think we are safe. This is the wrong forum for rolling coal and threads always end up like this. I say we stop telling them to get a pyro and encourage the stupidity to kill this crap off.
__________________
1989(94) F350 ExCab SB 7.3l IDI, C6, 4.10's, D60 front, ATS Turbo with 3" DP and upgraded housing pushin 10psi, 4" straight exhaust and 4" polished magnaflow straight through muffler, 5" stainless magnaflow tip, Full triple pillar, smokin early strokes and eatin rice. 1994 F150 body swap; I own the original FRANKEN-TRUCK(thanks Festus)
  #8 (permalink)
Old 02-12-2011, 08:15 PM
kenpobuck's Avatar
kenpobuck kenpobuck is offline
kenpobuck is gaining momentum as a positive member of FTE.kenpobuck is gaining momentum as a positive member of FTE.
I agree with you on that. But I did turn mine up one flat. Mine was kinda weak with no smoke at all. The one flat brought the power up and it only rolls coal with the pedal to the floor or pulling a long hill with a load behind her.
__________________
DON'T BUY IT ..FAB IT!!!!
81 BRONCO 6.9 IDI, ARP headstuds, 3" dual straight pipes, isspro pyrometer, T18 4 Speed, 10.25 rear, d60 front, 4:10 gears, 37x12.5x16.5 wrangler m/t's (humvee takeoffs), 4" body lift. I am building the Bronco Ford should have!
Kentucky Chapter Member
  #9 (permalink)
Old 02-12-2011, 09:45 PM
polarismuddman's Avatar
polarismuddman polarismuddman is offline
polarismuddman is starting off with a positive reputation.
Rolling coal is like Tinactin....it kills tailgaters on contact...that's the only thing it's good for. i used to be on the other side of the fence as I'm sure a few of us have been at some point in time. So, don't think we're only here to crap on your parade. The power gain with turning your pump up IS noticeable....and that's with a slight haze...heavy coal will get you nothing but headaches and a lighter wallet.
__________________
Junior
"Yea, I'm an oilburner....what of it?"
1989 F250 7.3 IDI, ZF 5-speed,4wd, worn out pump turned up a few flats, timing advanced, PowerKing tires, Group 31 batteries.
  #10 (permalink)
Old 02-12-2011, 09:49 PM
rupejosh's Avatar
1994 Ford F-250
For a power gain I'm guessing your ip and injectors need replaced thats where you will recover power if thats what your looking for.dont be hard on him guys we are here to help and inform.
  #11 (permalink)
Old 02-12-2011, 09:55 PM
That's the route I'd go......new IP new injectors and a turbo....
__________________
Junior
  #12 (permalink)
Old 02-12-2011, 10:10 PM
1989 Ford F-350
yeah there ya go, ill sell ya a 1993 factory turbo with an upgraded housing and upgraded downpipe. Thatll get ya down the road!
__________________
  #13 (permalink)
Old 02-12-2011, 10:11 PM
whoa whoa whoa...what we lookin at price wise? Are you in Canadia?
__________________
Junior
  #14 (permalink)
Old 02-13-2011, 04:36 AM
rupejosh's Avatar
1994 Ford F-250
careful guys keep it in the messaging system,your goin off topic
Tags
1993, 49, 73, 94, black, blow, blows, f150, ford, idi, international, lots, make, smoke, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
