56 ford wide fenders
I want to put bigger back tires on my 56 ford f100 but i dont want to tub the box. I see that there are wider glass fenders from mid fifties available. Has anyone used these? Reason i ask is do i need to change the running boards to meet the 3 inch wider fenders? Just curious as to how they fit up. Im thinking ill order the smooth running boards anyway, do i need to metal work those wider?
thanks
mike
thanks
mike
Received 4,119 Likes
on
There are a few on here that have the 3" wider fiberglass rear fenders on thier trucks, the stock running boards bolts to them without any modifications. There are others that have widened the steel fenders as well, try the search if you can get it to work for you, not likely as I noticed you don't have enough posts yet. You can also check out some of the magazine sites like Classic Trucks or Custom Classic Trucks, they both have plenty of articles related to this subject. The boys here that have done it should show up shortly and offer advice. Good luck and welcome to the forum.
Catanna69
19
08-10-2016 07:22 AM
MrMagoo187
02-25-2011 01:45 AM
Stephen67
01-03-2011 07:54 AM
