F-150 electrical problem
Old 02-11-2011, 03:06 PM
mudlakemike's Avatar
mudlakemike
mudlakemike is offline
I HAVE A 2005 f-150 LARIET 5.4 lt. I have been having a problem with my battery being drained. My stereo has been staying on once the truck has been turned off. It has also been coming on when the truck is parked all by itself and draining the battery. Sometimes when i am driving in the truck and turn the stereo on it wont come on, ten minutes down the road the stereo will all of a sudden come on. I have tried removing the relay for the stereo, no difference. I have also removed all fuses for the stereo and entertainment system, yet the draining of the battery is still occurring. If anyone has any idea what the problem could be i would apprciate any help.
Old 02-11-2011, 04:26 PM
Oldguy4's Avatar
Oldguy4
Oldguy4 is offline
There is a power control module that powers the radio. I don't know where is is, but I would suspect that. Did you pull fuses 1, 7 and 31?
Old 02-11-2011, 05:09 PM
Brack1's Avatar
Brack1
Brack1 is offline
Also, is it an aftermarket radio or stock?
Old 02-11-2011, 05:35 PM
mudlakemike
im not sure which fuse numbers it was now, im not where the truck is now, but i know it was every fuse that had to do with the stereo. The stereo is a stock stereo.
Old 02-11-2011, 07:41 PM
Wilber15's Avatar
Wilber15
Wilber15 is offline
I would guess it's an internal short in the radio. There is always power to the radio from fuses 7 and 31. You could also have a sticking Accessory delay relay in the CJB.
Old 02-20-2011, 06:50 AM
autojohn's Avatar
autojohn
autojohn is offline
Hi.The vehicle security module controls that. It has to get a door ajar signal to shut off accessories. The module is located behind the rear seat backrest on the left side. The most common problem is a corroded wire in the wire loom under the sill plate. It is a purple wire splice connection.
Old 02-22-2011, 11:16 AM
mudlakemike
Hay guys thanks for the sugestions, all fuses to do with the stereo have been removed. last night the truck was started to move in the drive way for snow clearing, and moved a second time, very short distance, only feet. When the wife went to leave for work this morning the damn thing wouldnt stat. Battery drained too much to start truck.Any ideas?
jnk317
05-17-2017 07:59 PM
bradphx
20
07-29-2015 09:05 AM
stevenjf88
06-10-2015 06:16 PM
brianjwilson
1983 - 2012 Ranger & B-Series
13
07-24-2013 10:29 AM
BURNSTOUGHFORD
36
12-02-2012 12:50 PM
Quick Reply: F-150 electrical problem
