2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
How to disable Daytime Running Lights (DRL) on '08 Expedition EL?
Old 02-11-2011, 02:45 PM
JSDSM's Avatar
JSDSM
JSDSM is offline
Would like to disable the daytime running lights (DRL) on my 2008 Expedition EL. Based on other Ford truck forums I believe it is as simple as pulling the DRL resistor. If that works on the Expedition...where is the resistor located? If not...any suggestions?
Old 02-11-2011, 03:15 PM
MCDavis's Avatar
MCDavis
MCDavis is offline
Welcome to FTE.
I would suggest running a search for the DRLs in the 09+ F150 forum for your answer. I would do it for ya, but I'm currently surfing the site via my phone and it's not the best medium.
Old 02-11-2011, 03:20 PM
JSDSM's Avatar
JSDSM
JSDSM is offline
Thanks MCDavis for the advice and the welcome to FTE. I will give that search a try.
Old 02-13-2011, 09:54 AM
bjtor's Avatar
bjtor
bjtor is offline
disabling daytime running lights
I took my 08 EL to the dealer to have the daylight running lights disabled - the service manager told me it had to be done by changing the settings via computer access.
Old 02-14-2011, 11:45 AM
JSDSM's Avatar
JSDSM
JSDSM is offline
That's what I believe I found out after looking all around front end for some sort of DRL resistor this weekend. More research led me to threads saying it is a programable setting. Thanks bjtor for confirming that. Will request that from dealer next time I am there. Did they charge you for that? If so...ballpark how much?
Old 02-14-2011, 11:56 AM
bjtor's Avatar
bjtor
bjtor is offline
They charged me $55 to do this, which was ridiculous especially since the truck was in for regular service anyway. Sometimes the dealer (in this case the Ford dealer!) has all the cards!
Good luck
Old 02-19-2011, 04:20 AM
cop on my back's Avatar
cop on my back
cop on my back is offline
Yes, it does need to be reprogrammed. I had this done on my 05 Mustang except I had to drive to the States to get it done as dealers in Canada won't do it because it would then not be legal.
Old 06-05-2011, 11:27 AM
JSDSM's Avatar
JSDSM
JSDSM is offline
Update...just had service performed at local Ford dealer shop. Idiots had know idea what I was talking about when I told them they should be able to disable the DRLs via computer settings. Anyone out there know specific instructions that would help a dealer shop perform this mod?
Old 06-05-2011, 11:56 AM
cop on my back
Well the guys at the dealership I went to had no idea either. They had to contact Ford to get instructions. Your dealership should be able to do the same.
Old 06-06-2011, 03:34 AM
nogo73's Avatar
nogo73
nogo73 is offline
Why not try the parking brake to see if just setting it a little bit will kill them? (just a couple clicks) Thats how we killed them on the GM vans at work? Not sure if ford is the same but worth a try?
Old 06-13-2011, 05:27 PM
cop on my back
It will work, but will make the Ebrake alarm go off constantly.
Old 06-14-2011, 01:53 PM
berry1234's Avatar
berry1234
berry1234 is offline
This isn't even a remotely viable option.
Old 06-14-2011, 02:13 PM
cstanley44's Avatar
cstanley44
cstanley44 is offline
I believe 06+ Fords could have DRL enabled/disabled via the computer system by a service tech. My father purchased an 06 Explorer in TX and exported it to Canada. It was shipped to Orlando to me first, and I had the dealer enable the DRL. The dealer in TX said Id have to add a module, the Dealer in Canada said Id have to add a module. I printed the following and the Orlando Dealer figured it out. Cost was $49
From a Ford Service manual
Daytime Running Lamps (DRL)
Special Tool(s) - Vehicle Communication Module (VCM) and Integrated Diagnostic System (IDS) software with appropriate hardware, or equivalent scan tool
Principles of Operation
NOTE: The smart junction box (SJB) is also known as the generic electronic module (GEM).
NOTE: When installing a new SJB, it must be configured for this feature, if originally equipped. Refer to Section 418-01.
The SJB controls the DRL by using various inputs to determine whether or not the DRL should be illuminated. These inputs include:
• Ignition switch position
• Headlamp switch position
• Headlamps on or off
• Transmission gear selection
Old 06-18-2011, 03:41 PM
JSDSM's Avatar
JSDSM
JSDSM is offline
re: partial engaging of parking brake...no go. 1 or 2 clicks and lights stayed on and chime sounded.
@ cstanley44 - looks like some good info. Will keep this next time have to visit the dealer shop. Is this something only dealer shops can do?
Old 09-15-2011, 04:43 PM
datman's Avatar
datman
datman is offline
Enabled DRL
I went to my dealer Mullinax of Kissimmee and the service guys are fantastic.
I asked them to enable the DRL for me, the service guy said He would have to ask the tech, I explained that they can disable/enable via the VCM and the tech said YES he can, 5 minutes later the DRL was enabled.
NO CHARGE, thanks Mullinax
But I forgot to ask them to enable the transmission gear selection that cstanley44 referenced.
I find sometimes I'm in 3rd gear instead of D
PS the DRL only works in gear, when placed in Park they turn off.
Quick Reply: How to disable Daytime Running Lights (DRL) on '08 Expedition EL?
