Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 02-11-2011, 02:45 PM
JSDSM's Avatar
JSDSM JSDSM is offline
1989 Ford Mustang
My Garage
JSDSM is starting off with a positive reputation.
How to disable Daytime Running Lights (DRL) on '08 Expedition EL?
Would like to disable the daytime running lights (DRL) on my 2008 Expedition EL. Based on other Ford truck forums I believe it is as simple as pulling the DRL resistor. If that works on the Expedition...where is the resistor located? If not...any suggestions?
  #2 (permalink)
Old 02-11-2011, 03:15 PM
MCDavis's Avatar
MCDavis MCDavis is offline
MmmmmmKayyyyy
2006 Ford F-150
MCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputation
Welcome to FTE.
I would suggest running a search for the DRLs in the 09+ F150 forum for your answer. I would do it for ya, but I'm currently surfing the site via my phone and it's not the best medium.
__________________
Chandler
Official Slackmaster #24
  #3 (permalink)
Old 02-11-2011, 03:20 PM
JSDSM's Avatar
1989 Ford Mustang
My Garage
Thanks MCDavis for the advice and the welcome to FTE. I will give that search a try.
  #4 (permalink)
Old 02-13-2011, 09:54 AM
bjtor bjtor is offline
Garage is empty, add now
bjtor is starting off with a positive reputation.
disabling daytime running lights
I took my 08 EL to the dealer to have the daylight running lights disabled - the service manager told me it had to be done by changing the settings via computer access.
  #5 (permalink)
Old 02-14-2011, 11:45 AM
JSDSM's Avatar
1989 Ford Mustang
My Garage
That's what I believe I found out after looking all around front end for some sort of DRL resistor this weekend. More research led me to threads saying it is a programable setting. Thanks bjtor for confirming that. Will request that from dealer next time I am there. Did they charge you for that? If so...ballpark how much?
  #6 (permalink)
Old 02-14-2011, 11:56 AM
They charged me $55 to do this, which was ridiculous especially since the truck was in for regular service anyway. Sometimes the dealer (in this case the Ford dealer!) has all the cards!
Good luck
  #7 (permalink)
Old 02-19-2011, 04:20 AM
cop on my back's Avatar
cop on my back cop on my back is offline
cop on my back is starting off with a positive reputation.
Yes, it does need to be reprogrammed. I had this done on my 05 Mustang except I had to drive to the States to get it done as dealers in Canada won't do it because it would then not be legal.
  #8 (permalink)
Old 06-05-2011, 11:27 AM
JSDSM's Avatar
1989 Ford Mustang
My Garage
Update...just had service performed at local Ford dealer shop. Idiots had know idea what I was talking about when I told them they should be able to disable the DRLs via computer settings. Anyone out there know specific instructions that would help a dealer shop perform this mod?
  #9 (permalink)
Old 06-05-2011, 11:56 AM
Well the guys at the dealership I went to had no idea either. They had to contact Ford to get instructions. Your dealership should be able to do the same.
  #10 (permalink)
Old 06-06-2011, 03:34 AM
nogo73's Avatar
nogo73 nogo73 is offline
nogo73 is starting off with a positive reputation.
Why not try the parking brake to see if just setting it a little bit will kill them? (just a couple clicks) Thats how we killed them on the GM vans at work? Not sure if ford is the same but worth a try?
__________________
2001 F-350 XL 5.4,4x4.
2009 Mustang GT
1989 Mustang GT
Iowa chapter Board Member
  #11 (permalink)
Old 06-13-2011, 05:27 PM
It will work, but will make the Ebrake alarm go off constantly.
  #12 (permalink)
Old 06-14-2011, 01:53 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Quote:
This isn't even a remotely viable option.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #13 (permalink)
Old 06-14-2011, 02:13 PM
cstanley44's Avatar
cstanley44 cstanley44 is offline
2008 Ford Expedition
cstanley44 is gaining momentum as a positive member of FTE.
I believe 06+ Fords could have DRL enabled/disabled via the computer system by a service tech. My father purchased an 06 Explorer in TX and exported it to Canada. It was shipped to Orlando to me first, and I had the dealer enable the DRL. The dealer in TX said Id have to add a module, the Dealer in Canada said Id have to add a module. I printed the following and the Orlando Dealer figured it out. Cost was $49
From a Ford Service manual
Daytime Running Lamps (DRL)
Special Tool(s) - Vehicle Communication Module (VCM) and Integrated Diagnostic System (IDS) software with appropriate hardware, or equivalent scan tool
Principles of Operation
NOTE: The smart junction box (SJB) is also known as the generic electronic module (GEM).
NOTE: When installing a new SJB, it must be configured for this feature, if originally equipped. Refer to Section 418-01.
The SJB controls the DRL by using various inputs to determine whether or not the DRL should be illuminated. These inputs include:
• Ignition switch position
• Headlamp switch position
• Headlamps on or off
• Transmission gear selection
  #14 (permalink)
Old 06-18-2011, 03:41 PM
JSDSM's Avatar
1989 Ford Mustang
My Garage
re: partial engaging of parking brake...no go. 1 or 2 clicks and lights stayed on and chime sounded.
@ cstanley44 - looks like some good info. Will keep this next time have to visit the dealer shop. Is this something only dealer shops can do?
  #15 (permalink)
Old 09-15-2011, 04:43 PM
datman's Avatar
datman datman is offline
datman is starting off with a positive reputation.
Enabled DRL
I went to my dealer Mullinax of Kissimmee and the service guys are fantastic.
I asked them to enable the DRL for me, the service guy said He would have to ask the tech, I explained that they can disable/enable via the VCM and the tech said YES he can, 5 minutes later the DRL was enabled.
NO CHARGE, thanks Mullinax
But I forgot to ask them to enable the transmission gear selection that cstanley44 referenced.
I find sometimes I'm in 3rd gear instead of D
PS the DRL only works in gear, when placed in Park they turn off.
Tags
06, 2001, 2006, 2008, daytime, deactivate, disable, drl, expedition, f150, ford, lamps, lights, resistor, running
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
