The heater in my Expedition does not blow any hot air.The AC works and I'm able to switch back and forth between panel, floor and defrost. Only cold air blows out. What is the problem and how can I fix it?
First thing is to pull your temp control **** and see if it's broken, if that's not it, your blend door, or blend motor could be broken, if that's not it, your heater core could be plugged up.
