2001 Expedition heater problems. - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 02-11-2011, 01:13 PM
doormansamaniego doormansamaniego is offline
doormansamaniego is starting off with a positive reputation.
The heater in my Expedition does not blow any hot air.The AC works and I'm able to switch back and forth between panel, floor and defrost. Only cold air blows out. What is the problem and how can I fix it?
Old 02-11-2011, 07:05 PM
madsonp's Avatar
madsonp madsonp is offline
madsonp has a good reputation on FTE.madsonp has a good reputation on FTE.madsonp has a good reputation on FTE.
First thing is to pull your temp control **** and see if it's broken, if that's not it, your blend door, or blend motor could be broken, if that's not it, your heater core could be plugged up.
Old 02-11-2011, 07:47 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
See the FAQs in the HVAC section...
86 f150 heater problems Dominiqui Archuleta 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 11-24-2015 06:09 PM
2000 Blowing luke warm air brimis 1997-2006 Expedition & Navigator 22 03-06-2013 08:49 AM
2005 heater problem dlgfords 1997-2006 Expedition & Navigator 0 10-19-2011 10:35 PM
No Heat from Defrost and Heater Mike-11 1997-2006 Expedition & Navigator 4 11-03-2010 12:19 AM
Heater Blows cold air blackexpedition 1997-2006 Expedition & Navigator 2 12-20-2008 08:18 PM
Tags
1999, 2001, 99, ac, air, bloe, expedition, ford, heater, heating, hot, navigator, problems, switch, wont, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
