brown wire mod on A4WD - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 02-11-2011, 01:16 AM
78ecf250cs 78ecf250cs is offline
78ecf250cs is starting off with a positive reputation.
Does anyone have any info about a wire modification on an a4wd system on a 99 expedition. Someone asked if it was done to my expedition in another thread, and I know nothing about it and did not get a response from them. So i thought id see if anyone might know something about it.
Old 02-11-2011, 12:09 PM
98EXPY 5-0 98EXPY 5-0 is offline
98EXPY 5-0 is starting off with a positive reputation.
If your truck doesn't have a 2WD option on the dial, cutting the brown wire (or putting a toggle switch in) will disable the front drive clutch when it's in AWD so you can stay in 2wd, even with slippage.
Mine has 2wd, so that is all I know.
Old 02-11-2011, 02:31 PM
Thaks for that info. Is the brown wire that is to be cut at the switch or at the transfer case or axle?
Old 02-11-2011, 06:22 PM
alloro alloro is online now
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Quote:
Originally Posted by 78ecf250cs View Post
Thanks for that info. Is the brown wire that is to be cut at the switch or at the transfer case or axle?
This rather lengthy thread should be able to supply you with any answers for the brown wire mod.
http://www.ford-trucks.com/forums/19...ition-4x4.html
Old 02-12-2011, 12:38 AM
Thanks alloro that helped alot.
ford expedition 2007 eddie bauer 4wd mbkabbasi New Member Introductions 2 04-12-2016 03:25 PM
'00 Expedition Engine and Rear end issues. mjkorcek 1997-2006 Expedition & Navigator 6 03-24-2016 04:31 PM
Comprehensive question(s) about the A4WD Re: binding TExpedition45 1997-2006 Expedition & Navigator 18 06-10-2015 08:47 PM
Expedition suspension on a 66 F100? tlharper3d 1961 - 1966 F-100 & Larger F-Series Trucks 7 05-22-2015 10:51 AM
Disable A4wd on 2001 Expedition 4x4? FarmLaw 1997-2006 Expedition & Navigator 119 03-27-2015 11:10 AM
Tags
1999, 2001, 99, a4wd, borwn, brown, disable, exedition, expedition, expidition, ford, mod, modification, pics, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
