Vacuum leak or...?
I of course disagree, and will state my case, how much you 2 want to agrue and hijack this thread is up to you.
The big incorrect ussumption both of you are making is that bringing fresh air into the crankcase is a good thing, it is not. Both of the reasons you stated are actaully reasons to not have a breather.
First the idea of freash air being a good thing, what does freash air have in it that blowby gasses don't, water vapour and oxygen. Both of these are bad for the internals of the engine and the oil, The inert gasses of blowby are better.
Second, a vacuum in the crankcase is a good thing, we should call PCV PCVacuum not ventalation. Vacuum in the crankcase is benificail for the same reason racers use vacuum pumps and dry sump systems. Maintaining a vacuum helps seal the engine and reduce windage drag. For us the sealing aspects are the big benifit. Many engines seals aren't all that great, most of all the crankshaft seals, these will always leak a little, better they leak in then out, pulling in air then leaking oil. Secondly by maintaining a vacuum under the pistons the rings are always being pulled in the same direction reducing flutter, blowby, and oil consumption.
I quarentee if u have a small oil leak or consume oil and have a PCV with a breather, plugging off the breather will reduce or eleminate it.
A PCV system is the exact same idea. If there's no breather filter and the system is closed off, blowby cannot move. But since the vacuum signal on the source-end is just as strong, positive atmospheric pressure will force its way through the weakest seal on the engine, be it an oil pan gasket, valve cover gasket, or what have you.
This isn't about me hijacking this thread; you're giving bad advice and I'm calling you out on it for the benefit of the OP. There's a reason it's called positive crankcase ventilation. If I'm wrong and you're right, then why have PCV systems been set up this way for over 40 years? Do you think Ford would waste the money installing breather filters on millions of vehicles for decades if it was the wrong way to do it?
I'm not sure what else to tell you. Your claim goes against basic physics. If you suck through a straw, air moves through the straw. If you put your finger on the end of the straw, you can't suck air through anymore.
Tell me why, outside of "because that's how Ford did it" you think a breather is better?
Trying to pass something through a seal does not prevent the seal from leaking.
You said yourself that the PCV system is a controlled vacuum leak, which is correct. If the PCV system was supposed to pull fumes out of a closed system, it wouldn't be a vacuum leak. The goal is that they're moved through (and displaced with clean air pulled in through the breather filter) at roughly the same rate that the rings let blowby escape past. This way, blowby fumes do not remain stagnant in the crankcase. When the rings begin to age, more blowby is pushed into the crankcase than the PCV system can pull through. That's when you see issues similar to what the OP is seeing.
That doesn't really matter in this case, though, because the PCV system is so basic that none of it is a mystery - it's simple physics. When you drink through a straw, you suck on one end, and iced tea moves through on the other end. If you were to seal off the top of your glass of iced tea and around the straw, the fluid level in the glass wouldn't be able to drop, and iced tea would not flow out of the straw when you sucked on it. When you suck air out of a balloon, the balloon must shrink. If the balloon was rigid and couldn't collapse, you wouldn't be able to suck the air out of it. PCV works on the same principle.
Just so everyone here knows, I apparently fixed it. I put the pcv valve back like it was supposed to be and put a new breather in on the other side and now it runs perfect!! What I want to do though is put the pcv valve on the other valve cover (pass. side rear) and the breather on the other (driver side front) so that it would be easier to add oil.
Pulling air through the weakest seals is not good. Pulling air through weak seals is going to make them weaker. The whole point of a PCV system is to pull the displaced air through a breather filter and not through a weak seal. Seals are supposed to seal. They're not supposed to let something pass through them. If the PCV system was intended to pull the displaced air through the seals in the engine, then how would the system work on a brand new engine? The breather filter gives the negative pressure an easy, non-obstructed path to move through without disrupting the seals on the engine, because those seals need to...well, seal.
b4hntn
1978 - 1996 Big Bronco
21
10-09-2018 03:53 PM
grandpas1974
04-08-2016 11:34 AM
78_79ford
26
08-28-2015 08:50 PM
Hellbore
05-24-2006 10:31 PM
