Improving gas mileage in lifted trucks.
Believe it or not my mileage went up with larger tires, this was really cause it had the effect of giving me taller gears, the right gearing can make a huge difference. So what kinda RPMs you running on the highway?
Next would be some ignition timing tweaks, careful need to know what your doing, but done right it's free.
After that tuning/tune up, and it goes on from there.
on
Everybody blows off the speedo issue like it's nothing, but it contributes to bad fuel milage in two ways. The first thing with larger tires is that the odometer is not clocking as many miles as you're actually travelling so your fuel consumption will look artifically high when you crunch the numbers. The second thing is that the vehicle is actually travelling faster than what the speedo shows, with 35s on an F250 for example when the speedo shows 60mph you're actually doing 70mph and with the aerodynamics of these trucks drag increases exponentially at these speeds so that 10mph will have a hugh effect on fuel consumption. Recalibating the speedo on '92+ trucks is a simple and free procedure accomplished by reprograming the PSOM HOW TO RECALIBRATE THE SPEEDOMETER ON 92-96 FORD F-SERIES AND BRONCO .: Articles, on older trucks you have to replace the driven gear on the end of the speedo cable, it's not free but it's pretty cheap and easy.
rusty-ford
18
01-30-2014 03:44 PM
buckeye21
1999 to 2016 Super Duty
63
07-06-2011 01:31 PM
black58
64
03-20-2006 11:04 PM
