2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
2007 Expedition stuck in park
Old 02-27-2011, 11:47 AM
rakar's Avatar
rakar
rakar is offline
Trailering
I have a 2007 Expedition and is stuck in park. Truck will not start. Any ideas?
Old 02-27-2011, 12:26 PM
chuck s's Avatar
chuck s
chuck s is offline
Page 265 of your owners manual...
If you cannot move the gearshift lever out of P (Park) with ignition in
the ON position and the brake pedal depressed, or when the ignition is
in the OFF position, it is possible that a fuse has blown or the vehicle’s
brakelamps are not operating properly. Refer to Fuses and relays in the
Roadside Emergencies chapter.
If the fuse is not blown, perform the following procedure:
1. Apply the parking brake.
2. Turn the key to the OFF position.
3. Remove the access plug on top of
the steering column.
4. Using a flat-head screwdriver or
similar tool, move the brake-shift
interlock actuator spindle toward
the left, apply the brake and shift
the transmission into N (Neutral).
5. Start the vehicle.
6. Reinstall the access plug.
Do not drive your vehicle until you verify that the brakelamps
are workin
-- Chuck
Old 02-27-2011, 12:44 PM
rakar's Avatar
rakar
rakar is offline
Trailering
a little jiggle....
I checked the brake lights and they are working....I jiggled the floor shifter and hit the brakes a couple of time and the truck started.....stopped and started the truck a couple of time without any trouble....while doing this I moved to revese and drive and parked. Then took it around the block and turned it off and tried it again and it would not. Jiggled the floor shifter again a couple of time and it finally started. Any ideas...
Old 02-27-2011, 02:42 PM
shorebird's Avatar
shorebird
shorebird is offline
You need to check the linkage on the transmission.
[IMG][/IMG]
In the photo you can see a yellow clip at the upper right.
That is where the shift cable is attached to the selector.
The shift interlock switch is in the black plastic housing below the clip.
If the lever does not stop in the correct position the interlock will produce the conditions you are experiencing.
You can remove the clip and then move the selector to neutral.
Have some one hold the shifter in the neutral position and replace the clip.
Now try to start the vehicle in with the shift lever in park.
It sounds as if the shift cable may stretched and the selector is not locating correctly.
Old 02-27-2011, 06:57 PM
rakar's Avatar
rakar
rakar is offline
Trailering
Could snow and slush build up and allow it to not go into park? We had a very warm day and all of the side streets were full of wet snow and slush. We had a very hard time getting it into park when we got home. Then I let it sit and it started....ice and snow melted? I took it out again in the slush and snow and I had the same problem. Roads are dry now going to try again and see what happens......
dsiedenburg
13
09-25-2017 10:43 AM
hharcrow
1997-2006 Expedition & Navigator
08-02-2017 04:11 PM
Haines25
06-09-2017 09:04 AM
Th3nicker
01-30-2017 10:59 PM
joiseystud
01-15-2011 04:59 PM
Quick Reply: 2007 Expedition stuck in park
