1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
turning off the seat belt warning
Old 02-10-2011, 07:04 PM
Longland's Avatar
Longland
Longland is offline
Is there a easy way to turn off the seatbelt warning on a 2002 f250.
Old 02-10-2011, 07:19 PM
redford's Avatar
redford
redford is online now
Received 1,560 Likes on 908 Posts
BeltMinder activation and deactivation procedure
1. Turn the ignition switch to the RUN (or ON) position. (DO NOT
START THE ENGINE)
2. Wait until the safety belt warning light turns off. (Approximately 1
minute)
• Step 3 must be completed within 60 seconds after the safety belt
3. At a moderate speed, buckle then unbuckle the safety belt 9 times,
ending with the safety belt in the unbuckled state.
• After Step 3 is complete, the safety belt warning light will be turned
on for 3 seconds.
• If Step 4 does not occur within 10 seconds at the end of Step 3,
BeltMinder will automatically exit programming mode without
changing its enable status.
4. Within 10 seconds of the light turning on, at a moderate speed, buckle
then unbuckle the safety belt.
• This will disable the BeltMinder feature if it is currently enabled. As
confirmation, the safety belt warning light will flash 4 times per
second for 3 seconds.
• This will enable the BeltMinder feature if it is currently disabled. As
second for 3 seconds, followed by 3 seconds with the light off, then
followed by the safety belt warning light flashing 4 times per second
for 3 seconds again.
5. After receiving confirmation, the deactivation/activation procedure is
complete.
Old 02-10-2011, 08:18 PM
Longland's Avatar
Longland
Longland is offline
Thanks...But I asked for EZ...
Old 02-10-2011, 08:30 PM
V10SD's Avatar
V10SD
V10SD is offline
It works, in the owners manual too.
Old 02-10-2011, 08:50 PM
TeamMudd's Avatar
TeamMudd
TeamMudd is offline
unplug it.......
under the seat the should be a plug that is attached the seatbelt receiver. unplug it and see if that does the trick. i have both of mine unplugged on my F250 and Excursion, i've unplugged quite a few as well, no ill effects so far.
Old 02-10-2011, 08:52 PM
redford's Avatar
redford
That is where I copied it from.
Old 02-10-2011, 08:54 PM
FordxFour's Avatar
FordxFour
FordxFour is offline
If the above suggestions don't work, try this...
Old 02-10-2011, 10:42 PM
2002 F350V10's Avatar
2002 F350V10
2002 F350V10 is offline
Just unplug the seat belt wires on the inside of the drivers seat belt located under the seat.
Old 02-11-2011, 07:43 AM
Downsea's Avatar
Downsea
Downsea is offline
Drove me nuts at camp for a year, ding ding ding. The easiest is to just push the belt release button on the drivers side after starting. Kills it until you shut it off again. Next time you start just push the belt release.
Old 02-11-2011, 10:58 AM
Johnny Langton's Avatar
Johnny Langton
Johnny Langton is offline
Do you want it off or not?
He answered the question, and that's the only way to disable that reminder.
JL
Old 02-11-2011, 11:45 AM
dchamberlain's Avatar
dchamberlain
dchamberlain is online now
The proper way to disable the seat belt reminder is with the instructions Redford posted. Cutting wires or unplugging connectors under the seat is liable to disable other safety features you don't want disabled, such as your air bags and seat belt pretensioners.
Old 02-11-2011, 01:21 PM
Longland's Avatar
Longland
Longland is offline
JL
Relax & take a chill pill! I was making a haha, I guess you never noticed all the silly smilies at the end of my post or the thanks i gave?
Old 02-11-2011, 01:24 PM
Longland's Avatar
Longland
Longland is offline
Yup, I agree thats the way I'll be doing it. Thanks...
Old 02-11-2011, 01:35 PM
Longland's Avatar
Longland
Longland is offline
Talking missunderstanding
START THE ENGINE)
minute)
on for 3 seconds.
complete.
Just in case you thought I was complaining with regards to your answer, I wasn't.It seams that someone else on here thinks I was complaining or something. I was just making a joke regarding the length of steps needed. Again thank you for your reply & thats the steps I'll be using.
Old 02-11-2011, 04:29 PM
dkf's Avatar
dkf
dkf is offline
I unplugged the the wire under the seat on mine. If I would have known about the procedure years ago I would have tried it.
Quick Reply: turning off the seat belt warning
