turning off the seat belt warning
BeltMinder activation and deactivation procedure
1. Turn the ignition switch to the RUN (or ON) position. (DO NOT
START THE ENGINE)
2. Wait until the safety belt warning light turns off. (Approximately 1
minute)
• Step 3 must be completed within 60 seconds after the safety belt
3. At a moderate speed, buckle then unbuckle the safety belt 9 times,
ending with the safety belt in the unbuckled state.
• After Step 3 is complete, the safety belt warning light will be turned
on for 3 seconds.
• If Step 4 does not occur within 10 seconds at the end of Step 3,
BeltMinder will automatically exit programming mode without
changing its enable status.
4. Within 10 seconds of the light turning on, at a moderate speed, buckle
then unbuckle the safety belt.
• This will disable the BeltMinder feature if it is currently enabled. As
confirmation, the safety belt warning light will flash 4 times per
second for 3 seconds.
• This will enable the BeltMinder feature if it is currently disabled. As
second for 3 seconds, followed by 3 seconds with the light off, then
followed by the safety belt warning light flashing 4 times per second
for 3 seconds again.
5. After receiving confirmation, the deactivation/activation procedure is
complete.
START THE ENGINE)
minute)
on for 3 seconds.
complete.
missunderstanding
START THE ENGINE)
minute)
on for 3 seconds.
complete.
START THE ENGINE)
minute)
on for 3 seconds.
complete.
