code reader fuel pressure 5.4 06 f250 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-10-2011, 05:57 PM
f2502006 f2502006 is offline
f2502006 is starting off with a positive reputation.
i have a good code reader and it says that the fuel rail pressure when running is 2.77 kpa how much pressure is that any help would be great. its a actron cp 9180 code reader
Old 02-10-2011, 07:41 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Google "metric conversions".... This ain't rocket science.
Old 02-10-2011, 07:45 PM
2.77 kpa is .40 psi. how is that enough for the truck to run. it runs fin unless you wot and it spit and stumbles at 3000. new maf new plugs and new o2s. any help would be great
Old 02-10-2011, 07:47 PM
only stumbles at 2800 to 3700 when wot than clears out. fuel pump ?
Old 02-10-2011, 08:16 PM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Start with the fuel filter.
Old 02-10-2011, 08:20 PM
its new two days ago. its the second in 90,000 miles, lots of brwn **** in it.
Old 02-10-2011, 08:27 PM
redford's Avatar
The new filter has a lot of brown stuff in it?
Just a guess, but this may be the cause of your problem.
Old 02-10-2011, 08:30 PM
well the old one had lots of brown fuel comming out of it. the first one had a blade of grass in it. wtf is that about. but hows it run with only .40 psi
Old 02-10-2011, 08:33 PM
redford's Avatar
40 PSI will run the truck, but not under high power demands.
Did someone put a bunch of crap in your tank?
Drop your tank and clean it out. You may need to replace the pump.
Old 02-10-2011, 08:37 PM
is 2.77 kpa at the fuel rail pressure sensor enough. if i am right its only .40 psi right am i not moving the decimal enough?
Old 02-10-2011, 08:39 PM
and whats the best way to remove fuel tank? got any detailed instructions
Old 02-11-2011, 11:23 AM
to the top
Old 02-11-2011, 11:43 AM
dchamberlain's Avatar
dchamberlain dchamberlain is offline
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
You are correct that 2.77 kPa is .40 PSI. I'm not a gasser guy, but that's barely enough pressure to measure, much less run an engine on.
I've seen a few instances where OBD-II readers will read a value and then incorrectly assume a unit of measure. I don't know what the 2.77 represents but I really doubt it is kPa. You need to find a better way to read fuel pressure.
Old 02-11-2011, 01:42 PM
i have no other way of testing fuel that i know of. i have no fitting on the fuel rail. any other sugestios
Old 02-11-2011, 01:44 PM
There should be a fuel pressure test port on the fuel rail. There has been on every fuel injected gas engine that I've seen. But like I said, I'm a diesel guy, not a gasser guy.
You might need to go down the forum specific to the engine you are working on. There would be more expertise there.
Best code reader for 9th gen F-150 command37 1987 - 1996 F150 & Larger F-Series Trucks 8 02-22-2016 09:35 PM
Code Reader Zebo* Computer Chips & Tuners 3 09-27-2012 11:10 AM
How to replace an oil pressure switch Brian Donoghue 1994.5 - 1997 7.3L Power Stroke Diesel 2 06-14-2012 08:07 PM
7.5 RUnning Rich, EEC-IV fail? Gatrucknut 1987 - 1996 F150 & Larger F-Series Trucks 32 01-21-2011 05:53 AM
Code reader KCMAGERS 1994.5 - 1997 7.3L Power Stroke Diesel 8 05-08-2007 01:36 AM
Tags
06, 1999, 2000, 2008, 54, code, engine, f250, ford, fuel, pressure, rail, reader, recommended, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
