limited slip? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
limited slip?
Old 02-10-2011, 04:46 PM
sanders46 sanders46 is offline
sanders46 is starting off with a positive reputation.
limited slip?
hey guys is there anyway i can tell if i have a limited slip rear end? ive tried a vin decoder with no help
Old 02-10-2011, 04:51 PM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
year of your truck?
on my 08 its on the tag on the door column between the front and rear doors.. mine is 4N (4.10 limited slip)
last row, right, under 'Axle'
Sam
Old 02-10-2011, 04:59 PM
wulfman wulfman is offline
wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.
Yes you have two tags on the rear diff cover, one tells you type of fluid if its LS it should say 75-140 synthect ,and the other one has these numbers v423f on top of tag then L73 10 5 3009 and mine has the LS so maybe yours match
Old 02-10-2011, 06:18 PM
wulfman as for what i can see one tag i can see v425f but it could be a 3 and then the other tag i can just see synthetic
Old 02-10-2011, 06:20 PM
Bobcat7 Bobcat7 is offline
Bobcat7 is starting off with a positive reputation.
Lift one tire, in neutral, and try and turn the tire. A worn LS will still fight you a bit.
Old 02-10-2011, 06:24 PM
i read the tag and if says v425 b not f sorry. and okay i will try that when i get the chance. thanks
Old 02-10-2011, 07:16 PM
You can also do a burn out and see if it lays down two black assss mark. Mine will
Old 02-11-2011, 09:17 AM
SuperDutyScaler's Avatar
SuperDutyScaler SuperDutyScaler is offline
SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.
i remember when my 04 did a posi instead of a peg leg.... the good ol days
Old 01-30-2013, 04:09 PM
Enduroman's Avatar
Enduroman Enduroman is offline
Enduroman is starting off with a positive reputation.
Anyone know which rear axle I have by these PICS? I can't see another sticker on it. Inside the driver's door it say D1 under AXEL. I need to find out which oil it takes, and Ford can't give me the Build List for a few days. Thx!
Old 01-30-2013, 05:23 PM
Firekite's Avatar
Firekite Firekite is offline
Shining Adonis
Firekite has a great reputation on FTE.Firekite has a great reputation on FTE.Firekite has a great reputation on FTE.Firekite has a great reputation on FTE.Firekite has a great reputation on FTE.
What year and model of your truck, and which factory options?
Old 01-30-2013, 05:24 PM
sammie0126's Avatar
sammie0126 sammie0126 is offline
sammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputation
Quote:
Sterling 10.5 D1 Limited Slip Differential 3.73
What rear end ratio is in my Ford , do I have positraction? - Drivetrain.com
Old 01-30-2013, 06:26 PM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
It is easier just to read your door sticker, under AXLE. Look closer, D1 is not a choice. 3L maybe, or 41?
AXLE CODES:
37- 3.73
3L- 3.73 LS
41- 4.10
4N- 4.10 LS
43- 4.30
4L- 4.30 LS
48- 4.88
8L- 4.88 LS
53- 5.38
5L- 5.38 LS
Old 02-01-2013, 12:37 AM
oracle oracle is offline
oracle is starting off with a positive reputation.
Sorry for the hijack of the thread but is it a good thing to have LS in a truck?
What are the advantages/disadvantages?
Thanks
Old 02-01-2013, 02:45 AM
Yahiko's Avatar
Yahiko Yahiko is offline
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
Quote:
AXLE CODES:
37- 3.73
3L- 3.73 LS
41- 4.10
4N- 4.10 LS
43- 4.30
4L- 4.30 LS
48- 4.88
8L- 4.88 LS
53- 5.38
5L- 5.38 LS
Redford.
Thank You for posting that.
To answer the question on what the LS is good for.
Lest say you get on some slick stuff on one side if you have a LS
then the other side would get some traction if you did not then you would
just sit there and spin one wheel.
Sean
Old 02-01-2013, 09:27 AM
Firekite's Avatar
Shining Adonis
To be a little more clear:
A differential's job is to allow the axle shafts (and thus the wheels and tires attached) to turn at different rates. That's because when you turn a corner or go anything other than absolutely straight, the outside tire needs to turn a little faster to cover a little more ground than the inside tire, just like the outside of a record is covering more ground per revolution than the inside, right?
Well, one side effect is that the power ends up getting transferred to the wheel that's traveling the fastest, and unfortunately that sometimes means the one with the least traction. Let's say you're on the side of the road in the rain, out in the country somewhere. Your driver's side tire is up on pavement, your passenger side tire is in the slick and sloppy mud. When you put it in gear and hit the gas, the tire in the slick mud is going to spin and spin while the tire on the pavement does nothing, because the tire with almost no traction is the one getting all the torque. I'm sure this has happened to all of us or at least seen it happen to others.
That's why they invented various "traction aids" such as a limited-slip differential, a locking differential, and various iterations on that theme. The LSD in particular means that due to one of several different mechanisms (usually spring-loaded clutch plates), when one tire ends up spinning too fast compared to the other, the clutch plates are forced together, transferring some of the power to the wheel that otherwise wasn't doing anything because it had all the grip.
So in your situation with one tire on pavement and one in the mud, the tire on the pavement ends up getting power now, too, and it is able to move you forward and out of the rut you've dug for yourself and hopefully up onto the road and home.
Rear axle swap in Excursion, different lengths? blloyd29 1999 to 2016 Super Duty 1 03-28-2016 07:11 PM
Limited slip vs Non gear oil jonnydz 1997-2006 Expedition & Navigator 1 07-18-2012 04:37 PM
Limited Slip Differential Holiver31 1973 - 1979 F-100 & Larger F-Series Trucks 2 02-06-2009 01:07 PM
limited slip {posi} charlierogers 1999 to 2016 Super Duty 18 09-30-2008 08:31 PM
limited slip ????? jasonlasvegas 6.0L Power Stroke Diesel 4 09-13-2004 05:31 PM
Tags
axle, code, codes, decoder, duty, f250, ford, limited, slip, super, trucks, v423f, v425f, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
