limited slip? - Page 2 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
limited slip?
Old 02-01-2013, 12:44 PM
oracle oracle is offline
oracle is starting off with a positive reputation.
ahh.... Thanks for the explanation. I'm glad my truck has it
Old 02-02-2013, 10:05 AM
Enduroman's Avatar
Enduroman Enduroman is offline
Enduroman is starting off with a positive reputation.
Quote:
Originally Posted by redford View Post
It is easier just to read your door sticker, under AXLE. Look closer, D1 is not a choice. 3L maybe, or 41?
AXLE CODES:
37- 3.73
3L- 3.73 LS
41- 4.10
4N- 4.10 LS
43- 4.30
4L- 4.30 LS
48- 4.88
8L- 4.88 LS
53- 5.38
5L- 5.38 LS
Thanks Redford and others. Its a 2003 (May) F350 Crew Cab 6.0. Here's the placard. I guess the only risk with this method is that the axel could have been changed before I got the truck. Unlikely, but possible.
Old 02-02-2013, 10:14 AM
Enduroman's Avatar
Just scrolled farther down on drivetrain.com (thx sammie) and see the D1. "Limited Slip Differential 3.73". Assuming that it hasn't been changed since new, should I use the 75W140 Synthetic Oil in it? Ford talked me into 2 containers of the Limited Slip stink juice too.
Old 02-02-2013, 11:03 AM
sammie0126's Avatar
sammie0126 sammie0126 is offline
sammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputation
Quote:
Yes 75W140 with limited slip additive, spec is 2 oz of the additive, but check that to be sure.
Or use Royal Purple which has additive already included. I have the V423B in my truck very similar to yours and I use Royal Purple 75W140 holds about 2 1/2 quarts and I do not have any additional LS additive in it.
Old 06-18-2014, 02:57 PM
Rickey Joe's Avatar
Rickey Joe Rickey Joe is offline
Rickey Joe is starting off with a positive reputation.
Quote:
Originally Posted by Yahiko View Post
Redford.
Thank You for posting that.
To answer the question on what the LS is good for.
Lest say you get on some slick stuff on one side if you have a LS
then the other side would get some traction if you did not then you would
just sit there and spin one wheel.
Sean
Mine says C1 any Ideas?
Old 06-18-2014, 03:03 PM
Rickey Joe's Avatar
axle
Old 06-18-2014, 03:05 PM
Rickey Joe's Avatar
axle
and 8800lbs means 3/4 ton right?
Old 06-18-2014, 03:43 PM
RickF350's Avatar
RickF350 RickF350 is offline
RickF350 is gaining momentum as a positive member of FTE.
Quote:
Gross Vehicle Weight Rating (GVWR). 8800lbs is the maximum Gross Vehicle Weight (GVW ) specified by Ford for your truck plus its load.
Old 06-18-2014, 04:01 PM
Rickey Joe's Avatar
C1 Axle code
I found it. Mine is the C1 3.73 limited slip, F-250/Excursion thank you for your support.
Old 06-18-2014, 04:03 PM
Rickey Joe's Avatar
Quote:
and " rickf350" Thank You for your support..
Old 06-18-2014, 04:39 PM
RickF350's Avatar
OK, let me try again. GVWR 8800lb = Ford saying that your truck and its load can not safely weigh more than 8800 lbs.
Old 06-18-2014, 05:43 PM
Rickey Joe's Avatar
ton
Yes sir. I understood the first time...........What I was wondering is if MY Truck is indeed a 3/4 ton? I do not know how to tell if it is or not.
  #28
Old 06-18-2014, 06:23 PM
RickF350's Avatar
Oh,OK. Check your vin here VIN Decoder | fleet.ford.com
  #29
Old 06-18-2014, 06:43 PM
Rickey Joe's Avatar
Thank You Very muck....You have been verry helpfull
  #30
Old 06-18-2014, 07:26 PM
asdrew's Avatar
asdrew asdrew is offline
asdrew is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by oracle View Post
Sorry for the hijack of the thread but is it a good thing to have LS in a truck?
What are the advantages/disadvantages?
Back in my country boy days, I saw many many trucks stuck with only one (2wd) or two (4wd) wheels turning. My Bronco had a trac-lok rear end and LS in the front. I could throw 4 rooster tails as I drove by every time.
I will always have LS or a locking differential to increase the chances of not being stuck (btw it WAS possible to get stuck in that Bronco, just farther into things - just sayin ).
Rear axle swap in Excursion, different lengths? blloyd29 1999 to 2016 Super Duty 1 03-28-2016 08:11 PM
limited slip rear differentail Marioj87 2004 - 2008 F150 7 01-28-2016 06:19 PM
How to check for Limited Slip Differential? Platinum08 1999 to 2016 Super Duty 5 12-10-2014 10:39 AM
Do I have a limited slip?? bigcountry1009 1999 to 2016 Super Duty 6 10-24-2014 07:58 PM
Lockers and Limited Slip axles horsepuller Offroad & 4x4 46 01-25-2014 10:08 PM
Tags
axle, code, codes, decoder, duty, f250, ford, limited, slip, super, trucks, v423f, v425f, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
