Which side is Bank # 1 or Bank #2 ? - Ford Truck Enthusiasts Forums
Old 02-10-2011, 03:07 PM
NAMDROF NAMDROF is offline
NAMDROF is starting off with a positive reputation.
99 7.3
I am throwing a 1395 code (glow plug) which someone pointed out in another thread is on bank #1. 1396 is Bank #2
Anyone know which side is bank #1? Driver side?
I am only guessing by 1,3,5,7 cyl drivers side
and 2,4,6,8 passenger side?
THANKS!
Old 02-10-2011, 05:22 PM
woodnthings's Avatar
woodnthings woodnthings is offline
woodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud of
1,3,5,7 are passenger side
2,4,6,8 are drivers side
Ford79's Avatar
Ford79 Ford79 is offline
Ford79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to behold
It's actually just the opposite, 1,3,5,7 passenger side and 2,4,6,8 driver side.
Damn, Ken beat me to it, and with a picture too!!
Old 02-10-2011, 06:25 PM
Shake-N-Bake's Avatar
Shake-N-Bake Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
Quote:
Originally Posted by NAMDROF View Post
99 7.3
THANKS!
Bank 1 is the right (passenger) side.
Bank 2 is the left (driver) side.
I think 1395 is a code for OBD trucks. What year are you working on?
EDIT: I re-read your post and see that you are working on 99 7.3. Still an odd code...
Old 02-10-2011, 06:35 PM
Is it a California truck or one with a GPCM? If so it sounds like the GPCM isn't getting power or is fried.
Old 02-10-2011, 06:36 PM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
Just a rule of thumb:
I don't know of any gasoline or diesel engine where the most-forward cylinder isn't number one. Notice the passenger's head sits a bit forward of the driver's? Not all "V" engines are like that example however, and some may instead have the left bank slightly forward, which would make the front driver's the number one on those engines.
This is also true of flat (or opposed) engines, too.
The odd-even, or side to side, subsequent numbering convention is up to the individual manufacturers. Sometimes the other bank's most-forward is number two.
Multi-row radials? Look it up in the maintenance manual! It's in there....
Pop
Old 02-10-2011, 06:39 PM
Quote:
I was wondering that too but I didn't think the GPCM came out until 2000. Of course I could be wrong...it's been one of those days...
Old 02-10-2011, 07:41 PM
Thanks for the info everyone!
Yes it is a Ca. Truck. Black label Catalyst truck. Bought it new in April 98. CC 4X4 Auto LB just coming up on 134K Just got the news yesterday to renew my tags I have to take it in and have it smogged! NEVER have had to do this before.
Truck is all original other than lots of front rotors, 1 cracked inj. cup over the years.
Just Monday it threw this 1395 code. Which in another thread is where I read it's a glow plug problem and in another thread someone described 1395 bank # 1 1396 #2.
To take it a little farther I tried clearing the code a couple days ago. It took. I then drove 2 miles to the store and it came right back. Did this a few more times with the same results. Today I got in and cleared the code. Drove the same route and stopped 2 other times similar to the day before and it now isnt throwing the code??? No longer check engine light popping on?? Whatcha think?
Old 02-10-2011, 07:59 PM
Could be the the oil temp is high enough to not require the PCM to energize the glow plugs. That would keep it from setting a code. Was it warmed up or cold after you cleared the codes today?
Old 02-10-2011, 08:01 PM
Quote:
Pop
Your going to lose a few with that one!!!!
Old 02-10-2011, 08:06 PM
tdpower's Avatar
tdpower tdpower is offline
tdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to behold
Quote:
He probably has a GPR shunt.
Old 02-10-2011, 08:38 PM
Yea, not too many of those in common usage around here!
Pop
Old 02-10-2011, 10:58 PM
Warm
Today was the same. It was cold when I first cleared the code from the day before, this time the service engine light stayed off, then stopping and starting at full operating temp for test starts after that with NO codes showing up. The day previous I did the exact same thing and every time I stopped cleared the code and would fired it up after waiting for it to go thru its starting cycle the check engine light would come on. I Will try it again in the morning and report back.
Old 02-11-2011, 06:16 AM
dn29626's Avatar
dn29626 dn29626 is offline
dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.
...Bought it new in April 98...
A ford truck diesel from 1998, really?
Old 02-11-2011, 08:45 AM
Quote:
Considered an early '99.
2006 ford f150 misfire/poor accelleration fixed hofec1 2004 - 2008 F150 30 09-01-2016 07:17 AM
2004 Lincoln Navigator - 5.4 Intech - P2197 O2 Sensor Signal Biased/Stuck Lean (Bank 2 Sensor 1) Kid Clean 1997-2006 Expedition & Navigator 18 03-03-2015 10:23 AM
bank 1 bank 2 teamlx88 1997-2006 Expedition & Navigator 11 09-28-2012 11:41 PM
which side is bank 1? ilbigmike Explorer, Sport Trac, Mountaineer & Aviator 4 01-10-2011 12:21 PM
bank1 vs bank 2 motorhead748 Explorer, Sport Trac, Mountaineer & Aviator 3 10-08-2009 07:59 AM
Tags
01, 1, 35, 46, bank, bank1, bank2, cylinder, diesel, engine, escape, f350, ford, location, motor, side, truck, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
