Good article on Ecoboost in F-150
Farm Industry News has a report on the Ecoboost. Says 25% better fuel mileage than present. Hope that this hasn't been posted here already.
Ford's EcoBoost engine technology | A boost up
Since the F-150 doesn't currently offer a V-6 power plant, will the Ecoboost provide 25% better economy than the 5.4L or the 4.6L 3v or the old 4.6L workhorse.
So, well take the worst case scenario and use the FX4 with the 5.4L and 3.73 axle rated at 14 city and 18 hwy.
By thier numbers, that becomes 17.5 city and 22.5 hwy.
Or if you use a 4x2 with the 3.15 axle rated at 21 hwy, you should jump to 26.25.
The Taurus and Flex aren't even rated to achieve these numbers, how will a 5000 lb 4x2 truck do it?
I think the 5.0L is going to be the way to go.
Tim
Tim
If that's the way you want to go then good luck with that. Historically, Ford's turbo gas burners haven't exactly answered the call of durability. This one may be different. I'm not willing to find out. It's speculated and posted here that the naturally aspirated 5.0L will produce very similar power numbers to the Ecoboost with MPG's very similar to the 2009 5.4L equipped trucks. I'm good with that.
I'm not trusting the new 6.7L or the ecoboost until time has proven that they are what Ford says they will be.
Tim
Tim
+1 on the Ford turbos. I had an '88 T-bird Turbo Coupe that had 198,000 on it when i sold it to my sister. Oil changed every 5000 and ran only Mobil 1 synthetic from day one. The only engine problem I ever had was an intake hose that blew a clamp and came off. Quick 5 minute fix with a new clamp. And, it routinely got almost 30 MPG on my daily 140 mile commute.
Gentlemen, I'm simply trying to figure out which existing F-150 drivetrain that the ECOBOOST will surpass by 25% in MPG's.
The T-bird Turbo Coupe was a smaller and lighter car than the Flex and Taurus and the engine was a four banger. John, I'm impressed with the endurance of yours. I knew a few people that had not so good luck with theirs.
I want Ford to succeed with all of thier ventures, I'm just not willing to stick my toe in the water first.
Tim
Tim
I know what you mean Tim. My T-bird was a fantastic car. I think a lot of that can be attributed to my maintenance routine on it. Not all, but most vehicles are like that. If you are rigorous with the maintenance and drive responsibly, they usually repay you with longevity.
The EcoBoost is an outstanding engine. However, I don't think it's quite living up to some of the hype about its fuel mileage. That said, you have to pay to play. I personally don't see it getting the projected / estimated mileage in the F-150 that some are saying it will get. And, I think it will see a significant drop off in MPGs when towing or hauling heavy. Beyond that though, from the looks of the current torque curve of the 3.5 EcoBoost, if it stays the same in the trucks or improves slightly, it's going to be one hell of a pulling engine. If they reach that projected goal of 400 lbs./ft. of torque with the flat torque curve it currently has, watch out.
Reading the article, it would appear that the 3.5L EB is only vaguely similar to the conventional 3.5L. It seems that the EB was built with different alloys and the motor basically re-engineered to handle the heat and TQ output.
Tim
I guess all we can do is wait and see Tim. I'm cautiously optomistic that it'll be a great engine. Ford seems to be on a roll as of late with their ongoing engineering and quality improvements. I hope that it continues as they now are on par with and ahead of some of the more respected names in the auto business in terms of quality. Hopefully, they'll have it right straight out of the box with this and the new diesel in the Super Duty.
Right now, I'm torn between trading trucks or keeping mine and buying a new Taurus. I'm going to have to do a little pondering.
MEEEEEEEEEEE too John. I was just telling my bride last night that I've nearly abandooned the idea of getting a new truck as it's simply not a wise move right now. My '88 is running like a Mack truck and I can't justify letting it go.
I've become increasingly intrigued by the new Taurus and Fusion. And, I've become quite spooked by the future of fuel prices.
Tim
